One Electron Ubt-2 Se Opt's Cheap One Electron Ubt-2 Se Opt's Cheap - diyAudio
Old 19th April 2003, 12:47 AM   #1
mg16 is offline mg16
Default One Electron Ubt-2 Se Opt's Cheap
I HAVE A PAIR OF ONE ELECTRON, UBT-2 SINGLE ENDED TUBE OUTPUT TRANSFORMERS.
I HAVE BEEN USING THEM IN MY DIY 45 TUBE AMP FOR ABOUT A YEAR. THEY AND THE 45 AMP SOUND AMAZING. UNFORTUNATLY I HAD TO SELL MY LASCALA HORNS. THERE IS REALLY NO OTHER SPEAKER SYSTEM THAT A 45 TUBE AMP WILL DRIVE. 2 WATT OUTPUT.
EVEN THOUGH THE AMP IS NICELY MADE, I FIGURE IT WILL BE TOUGH TO SELL A DIY AMP. I AM THEREFORE PARTING IT OUT UNLESS SOMEONE WANTS THE AMP INTACT.
IT IS THE ERIC BARBOUR "SINGLE ENDED GLORY" 45 TUBE AMP, WITH PREMIUM PARTS.
MIT MULTICAP COUPLING CAPS, VISHAY RESISTORS, VT-231 6SN7 DRIVER TUBE, ETC.
THESE OPTS WILL WORK WITH 300B PROJECTS EQUALLY AS WELL. ALONG WITH 50, AND OTHER TUBES.
4800 PRIMARY TO 4/8/16 SECONDARY.
THE SPECS ARE HERE:
http://www.tubesandmore.com/
PAIR UBT-2 OPTS FOR $100
WHOLE 45 TUBE AMP WORKING PERFECTLY WITH 3 SETS OF TUBES: (2) SETS OF RCA CUNNINGHAM 45'S THAT SOUND GLORIOUS ,AND A PAIR OF $300 EMMISSION LABS 45'S THAT SOUND ROUGH IN THE LOW END.
WILL THROW THE EL'S IN FREE.
$300 + SHIPPING COSTS FOR EVERYTHING.
NEED MONEY DUE TO FAMILY ILLNESS.
THANKS FOR LOOKING,
MG16
Old 19th April 2003, 01:00 AM   #2
fragman56 is offline fragman56
Default Sorry to hear
about your circumstances. I am interested and emailed you.
Rick
Old 19th April 2003, 01:02 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default TOO BAD...
These are not the only high efficiency speakers around, there are alternatives.
That amp is certainly the only girl I do NOT want to view "nekkid".
Try to sell it as is or better still keep it...unless you're really dying for cash?
BTW, in case you do decide to sell the amp there is a "Trading Post" section here at the forum made for that sole purpose.
Frank
Old 19th April 2003, 01:47 AM   #4
Default lascala
Frank,
I should have said no speaker that I can afford right now, that a 2 watt 45 tube amp will drive.
Of course there are many, but money is tight, and I am using 89db/1w/1m bookshelf Infinity qb's that I paid 100 for on ebay.
2 watts wouldn't even make static through them.
MG16
Old 19th April 2003, 02:09 AM   #5
fdegrove's Avatar
Default RE:lascala
Sorry to hear about that, the only thing we can do to help you is give you "sound" advise....well, some better than other but still.
Whishing you all the best,
Frank
One Electron Ubt-2 Se Opt's CheapHide this!Advertise here!
Need ideas for amp with 2A3, One Electron UBT-3 jaylgordon Tubes / Valves 3 5th April 2009 08:42 PM
Anyone ever had issues with One Electron? audiowize Tubes / Valves 3 12th October 2008 11:16 PM
One Electron vs. Transcendar wrenchone Tubes / Valves 23 25th September 2006 08:52 PM
Lundahl vs. One Electron jim Tubes / Valves 23 31st March 2003 01:01 PM
Copyright ©1999-2017 diyAudio
