diyAudio Sponsor
Old 1st March 2009, 03:46 PM   #1
Default Power transformer star ground
Hi I have been referring to Aiken Amps article on star grounding and he says in the addendum #3:
"You have to run the centre-tap of the power transformer B+ winding (or bottom of the B+ winding if you are using a bridge rectifier) directly to the first filter cap without going through the chassis..."
I have decided to use this method for my power stage grounding and I am using a bridge rectifier and have no centre tap on the transformer. Am I supposed to take my transformer ground wire from before the rectifer (AC) or from between the rectifier and the first cap (DC)?
Old 1st March 2009, 03:58 PM   #2
HollowState's Avatar
You would ground the DC negative side. Never the AC.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 1st March 2009, 04:00 PM   #3
Thank You! That's what I suspected, but when aiken said the wire goes directly from the transformer I got confused!
Old 1st March 2009, 04:04 PM   #4
That would be true if you were using a full wave circuit which involves the center tap of the HV winding.
Old 1st March 2009, 04:13 PM   #5
I see - thats usefull to know too. Thanks again!
star ground vs. ground plane Sebastiaan Chip Amps 15 10th May 2009 05:05 PM
Star ground help g(f(e)) Tubes / Valves 26 24th December 2007 10:08 PM
Will this amp need a star ground? ghetto Chip Amps 3 25th August 2007 05:25 PM
Ground star JORGETronic Tubes / Valves 1 2nd June 2007 02:50 AM
Ground planes instead of star ground svokke Chip Amps 3 22nd October 2003 01:01 AM
Page generated in 0.07070 seconds (77.63% PHP - 22.37% MySQL) with 10 queries
