| diyAudio Sponsor | ||
I'm looking for a new technique for chassis construction that will offer better shielding than I currently am achieving as I embark on some preamp projects.
My current technique is sort of a modified top plate: a 3 piece glued wood front + sides, an aluminum top plate and aluminum back plate. I use aluminum because my shop is not so well equipped, and I need the softness of aluminum to get a tight fit on non-round fittings such as IEC sockets. I try to use spacing and orientation to get as much isolation between the power and signal side as possible. I use DC for heaters. I am thinking of adopting a combination chassis: a commercial steel enclosure for the PS attached to a commercial aluminum enclosure for the signal circuit. Holes with grommets would allow power (only DC) to pass onto the signal side from the PS side. The drawbacks as I see them are dealing with cuttouts for the abovementioned IEC socket in steel and galvanic corrosion (hardly a concern for me). Any experience to pass on or pitfalls to my plan?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
I use the steel chassis from Hammond. If you can find greenlee punches, especially the iec socket punch for less then a small fortune then your golden. Currently, I outline the shape, drill out as much as I can, and then file it to shape. This technique sucks, but it works. I used hole saws with drill bit guides for my last project, this sucked as well, but also worked. I have my amp in the middle of all my other gear and I get no cross talk or interference so I would say I find it well shielded.
#3 |
Why not try a commercial aluminum chassis for the power supply as well ? With seperate chassis you may be able to position your power supply so that magnetic coupling to the amplifier section is not a problem. ( I am assuming magnetic sheilding is why you want steel for the power supply chassis , or was it a matter of heavier components eg transformers in the power supply ?).
Robert McLean |
#4 |
Lead Belly,
I use a "similar" method to the one you are using as far as wood and aluminum. What I do is use copper clad PC board. I prefer the kind with copper on one side only. I affix the PC board to the underside of the "top plate" of veneered plywood temporarily while making "pilot" holes for the sockets etc that pass thru to the top. Then with them separate I can clearance the top plate of wood with larger holes and the copper clad for the sockets. Since you are using DC on the filaments also I suspect that possibly your noise is not from the PS components but possibly from Ripple on the DC. What type of rectification and regulation are you using on the filament supply? I went to DC on a Preamp project and it was NOISIER than the AC because of lack of ripple rejection and too little filtering. Unless you plan to run the preamp on a boat at the ocean I highly doubt that galvanic action will be an issue with steel and aluminum chassis, but it seems to me that you are going through a lot of trouble to eliminate noise that might not be caused by what you think. The method of PC board and wood works quite well and allows me to place grounds any where I want as well as providing a "clean" look on the underside. Attached is a picture of the "amp" section of my 6V6PP. This was my first attempt with the wood and PC board construction. One nice feature is this. By minimizing the "external" connections of the "board" to the PS and input you can remove the board from the amp chassis and make changes on the bench without all the chassis and things in your way. For instance this amp has only a ground, B+, signal and 6 OPT wires to "remove" then with a few screws I can take the entire "amp" out of the chassis and do what I want. |
#5 | |
#6 |
My latest 'junk-box' project was made on a Plastic box, and I'm quite pleased with it as its only cost a couple of quid to do......
Its stereo power-amp based very basically on a David-Berning screen-drive amp. Valve line-up is- Gain stage, 6SL7GT. Phase-splitter, 6SN7GT, Second gain-stage, 12AT7 MOSFET screen-drive stage, with independant bias adjustments Output pair, 12GE5 'sweep-tubes' running at 3mA idle-current The tranformers were rescued outta a defunked Heathkit amp rated for around 12W per channel. All point to point, transformers and valve sockets mounted directly onto the plastic, but each metal item has a grounding-lead back to the centre-point of the full-wave centre-tap of the transformer. I use AC heating, but biassed to +45V (Without this, Hum is intolerable....) There is No Hum or any 'picked-up noise' when this amp is running. Not even when you stick your head right up to the speakers.... --Guess what I'm trying to get at, Shielding is Good, BUT Don't Rely on it Completely, Good circuit Layout and design are more important than just shielding.....
Das Beste Oder Nichts |
#7 | |
#8 | |
#9 |
Leadbelly,
A "technically supported" critique of what? Using Steel chassis? Been done for years. Using aluminum chassis? also been done for years? All we are getting at is NO TECHNICAL details have been offered to critique! Give us an EXAMPLE of why you think your current technique is sub-par to your proposed technique! If shielding the PS from the Signal circuits is important why not separate them altogether onto separate chassis and shield them with 2 inches of lead? I am just trying to prevent you from chasing down a gremlin that might not be worth chasing in the end. Unless you can verify the negative effects of the MI then why try to mitigate them? |
#10 | |||
I am thinking of adopting a combination chassis: a commercial steel enclosure for the PS attached to a commercial aluminum enclosure for the signal circuit. Holes with grommets would allow power (only DC) to pass onto the signal side from the PS side. Quote:
| Shielding ..... | sakis | Solid State | 9 | 20th July 2009 07:34 AM |
| How to star ground to Chassis without a Chassis?? | Minion | Chip Amps | 10 | 5th November 2006 04:28 PM |
| Steel DAC chassis Shielding Question | fastcat95 | Digital Source | 1 | 2nd January 2005 06:36 AM |
| Where to get chassis or chassis parts in Vancouver? | Prune | Parts | 1 | 7th July 2004 05:37 PM |
| Shielding | peterr | Everything Else | 2 | 17th September 2002 11:57 AM |
| Page generated in 0.13617 seconds (81.44% PHP - 18.56% MySQL) with 11 queries |
