diyAudio Sponsor
Old 28th February 2009, 11:37 PM   #1
SpreadSpectrum's Avatar
Default -500V Maida regulator inquiry
I am about to embark on my second Maida regulator design. I am a bit concerned, though. I am unable to find a pass device rated for a voltage greater than the raw DC supply voltage. Is this only a concern if you want the supply to survive a short circuit? I am willing to live with destruction of the components if I am dumb enough to short the output.
I am planning on making a -500V regulator with about -560V raw DC.
Old 1st March 2009, 12:11 AM   #2
SY's Avatar
Power on and power off are a concern. I haven't tried a Zener across the pass device yet, but that might give you some protection.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 1st March 2009, 12:24 AM   #3
I don't plan on having any downstream capacitance, so I guess I'll try a zener across the pass device and see how reliable that is. With minimal capacitance there won't be much pinning the output to ground at power-up or a bunch of energy to bleed off at power-down. Hopefully, the Zener won't see any huge current surges.
I've also thought about two pass devices in series. Dropout voltage would be higher, though.
I just wish there was an 800V p-channel FET.
Old 1st March 2009, 02:21 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
if you have a seperate winding for the -500v, just regulate the high (ground) side... then you can use Nch stuff.
Old 1st March 2009, 02:44 AM   #5
jackinnj's Avatar
As recommended in "The Art of Electronics".
If you have to do the high-side there are a lot of HV MOSFETs.
Old 1st March 2009, 04:08 AM   #6
I was going to use a Hammond 278CX(800VCT) to create a +-500V supply, so windings are not separate. I guess I could consider a custom wind from Edcor. That may be the most reliable solution.
Old 1st March 2009, 10:05 AM   #7
disco is offline disco  Netherlands
disco's Avatar
Did you consider the T-reg or the Swenson Reg instead ?
jaap
Maida regulator Andrewc556 Tubes / Valves 21 31st December 2010 03:29 AM
Using a Maida Regulator with a CCS BL21DE3 Tubes / Valves 4 17th July 2008 04:42 PM
Maida regulator billr Tubes / Valves 15 23rd September 2007 03:19 PM
Maida Regulator Parts Eli Duttman Tubes / Valves 6 2nd June 2007 12:56 PM
Maida's regulator mark_titano Tubes / Valves 3 29th January 2006 02:26 PM
Page generated in 0.07894 seconds (77.20% PHP - 22.80% MySQL) with 10 queries
