Bell 2122 volume drop off
Old 1st March 2009, 12:06 AM   #1
bereanbill is offline bereanbill  United States
Question Bell 2122 volume drop off
I have a Bell 2122 Phono/Mic amp with a problem: after about 3/4 volume, the output level drops off. Any suggestions for a novice, hobbyist-type would be greatly appreciated. Thanks
Old 27th March 2009, 08:08 AM   #2
m6tt is offline m6tt  United States
you either have a bad pot, or a parasitic oscillation that is being picked up at higher gain settings.
Does the amp have a resistor in series with the first grid?
Try 50-100k between input jack and first grid. Eventually you may want to put 1k series resistors on the power tube grids, but that's only if the oscillations continue. These resistors acts like a filter using the tubes internal capacitance to AC ground (B+)...they form a low-pass at fairly high frequencies (generally above hearing, def above guitar amp range).
Have you tried the "chopstick" method of pocking around with an insulated chopstick to see if you can affect the frequency/onset of the problem? This checks to see if stray coupling or capacitance is introducing a signal back into earlier stages leading to a positive feedback loop.
Try removing all cathode bypass caps, they're electrolytic, way old, and they're not always good for tone when overdriven. They will also tend to help the valve amplify radio frequencies spuriously as they get wonky.
Make sure all internal wiring is short, and isn't all running parallel with other wires, long parallel wires can couple better than short, perpendicular ones.
Experiment with different feedback cap/resistor combinations...you probably need less high frequency response somewhere.
If this thing is as old as I'm guessing, I would at least consider replacing all the resistors in the power supply with newer, quieter resistors, replacing the power supply caps, and possibly the coupling caps into the power tube grids. This will ensure quiet, hiss-free operation, making a much better guitar experience.
This is honestly the hardest part of design for me, since I always do point-to-point. It takes some practice to find the culprits...make sure you are using a big soldering iron, it makes all the tube stuff (esp. old tube stuff) easier to work with. The radioshack 30w is the worst thing ever done to newbies!
Bell 2122 volume drop offHide this!Advertise here!
Intermittent drop-out and crackle at low volume Sophie424 Solid State 6 25th February 2009 06:30 PM
Marshall volume drop off help 4lf Instruments and Amps 3 7th February 2009 08:26 PM
Bell 2122-B integrated amp - tube suggestions Lockerpuzzle Tubes / Valves 0 30th April 2007 10:41 PM
Bell schematic hurdy_gurdyman Tubes / Valves 0 15th April 2003 01:21 AM
