diyAudio Sponsor
Old 28th February 2009, 08:35 PM   #1
Default Hum problem
I have built a phono preamp with a TL-783 regulated power supply in a separate box. I still have a slight hum which seems to be coming mostly from one of the speakers. I changed the position of the valves but the problem remains.
The first filter cap -ve is connected to mains earth via a 27ohm hi-watt resistor paralled by a 0.22uF film capacitor. From the first cap it goes to regulator -ve and from there to the phono central ground point. The first and second phono stages are also separate and they each go to the central ground point.
The thing which is nagging me is that the two phono channels both share the same Ov busline. Is this OK or should I have made separate ground lines for each channel?
Any help or pointers to solve the problem will be greatly appreciated.
Joe A
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 10:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 07:14 AM
Page generated in 0.06649 seconds (72.66% PHP - 27.34% MySQL) with 10 queries
