| diyAudio Sponsor | ||
Friends
Anyone have experience with polystyrene capacitors as coupling capacitor in output tube stages ? How it sound ? Thanks, Aldovan |
#2 |
Haven't tried myself and here's why... polystyrene's are inductive by nature. This could cause stability issues in some designs/layouts. Ones that big in value are also pretty pricey. ![]() Cheers! |
#3 |
Inductive ? Why ?
Do not is a film capacitor as polyester, per exemple ? I never see a post about this problem. Thanks, Aldovan |
#4 |
MultiCap RTX series parts exhibit very low ESR/ESL. So, inductive destabilization is not a problem. However, along with the substantial cost, polystyrene film is sensitive to heat. The environment near power O/P tube types is usually quite hot.
IMO, polystyrene dielectric caps. are best saved for use in comparatively cool environments. That's not a happy decision, when the fact that only PTFE is more transparent than polystyrene is taken into account.
Eli D. |
#5 |
I used MIT and then REL RTX (polystyrene and foil) caps in my power and pre-amplifiers for years, and thought they were great until I heard some similar Teflon types which were clearly better. I thought the RTX were a bit bright sounding, but in terms of resolution were better than the CDE and Mallory film caps I had used previously, and also sounded much cleaner as if a layer of grunge had been removed.
I never had any heat induced issues with these capacitors, I just found something I liked better. These days I use mainly Vcaps, REL TFT (Teflon), one of the various surplus Russian made Teflon coupling caps people have raved about or transformers.
www.kta-hifi.net |
#6 | ||||
Take a look at the (axials show this best) polystyrene caps in a tape recorder or RIAA stage. Notice the leads are offset? I've neasured as much as 20uH inductance on a new manufacture 3000pF polystyrene cap. A coupling cap like you're talking about, say 0.1uF, could be has high as 100uH. Quote:
![]() Quote:
Cheers! |
#7 |
But the polyester and polystyrene do not have the same construction ? Both do not have a film, a isolator and other film ?
I do not see differences . Polyester have a inductance, too. Aldovan |
#8 |
I have recently started using polystyrene/tin foil couplers in my power amps. They have a combination of transparency to fine detail and tonal richness I have heard in nothing else. Mind you, I have not tried the megabuck teflon caps. They are not terribly expensive, but they are big and heavy enough to be a mounting problem, and do not come in high enough values for my preamp output.
Poinz likes 'em. Aloha, Poinz AudioTropic |
#9 | |
www.kta-hifi.net |
#10 | |
Martin Rupp |
| DC-coupling of tube stages | revintage | Tubes / Valves | 15 | 21st April 2011 06:34 AM |
| how much important is a dc coupling output capacitor? | umut1001 | Solid State | 11 | 14th January 2008 11:00 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 04:09 AM |
| the choice of the output coupling capacitor | Dominique | Parts | 7 | 10th August 2004 01:26 AM |
| Easy ways of measuring output impedance of tube stages | stigla | Tubes / Valves | 4 | 16th May 2003 12:37 PM |
| Page generated in 0.13093 seconds (82.78% PHP - 17.22% MySQL) with 10 queries |
