diyAudio Sponsor
Old 3rd March 2009, 11:11 PM   #11
kevinkr's Avatar
Originally posted by MRupp
There are obviously 2 types of polystyrenes, the "laid-in" type with the connectors wrapped in with he foil, and the "extended foil" type where the leads are welded to the foils at both ends of the cap, much in the same way as other types of capacitors.
"Laid-in" types are common below 10nF/0.01uF and "extended foil" types are relatively standard for higher values (in the USA anyway) and types that are deliberately intended to be low inductance like the RTX. FWIW I have never found inductance to be a particularly big issue with foil types in most circuits - input impedances to succeeding stages are usually high enough that the inductive loss term is irrelevant at audio frequencies - and in any event are still likely to better than most other types other than clearly audio unsuitable ceramics and micas. (Some Russian micas are reputedly quite good for audio, but I have not yet tried these.)
www.kta-hifi.net
DC-coupling of tube stages revintage Tubes / Valves 15 21st April 2011 05:34 AM
how much important is a dc coupling output capacitor? umut1001 Solid State 11 14th January 2008 10:00 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
the choice of the output coupling capacitor Dominique Parts 7 10th August 2004 12:26 AM
Easy ways of measuring output impedance of tube stages stigla Tubes / Valves 4 16th May 2003 11:37 AM
Page generated in 0.06335 seconds (67.74% PHP - 32.26% MySQL) with 10 queries
