diyAudio Sponsor
Old 27th February 2009, 04:47 PM   #1
dshortt9's Avatar
Default Anode chokes DIY?
C-cores are available on e-bay.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260368475588
How would I wind some 100HY 30ma. anode chokes?
Wire size? Turns? Gap?
Is any sectioning or interleaving needed? I'm obviously a newbie at this, but it should be much easier than winding a full transformer.
HELP!
Old 27th February 2009, 06:31 PM   #2
nhuwar is offline nhuwar  United States
nhuwar's Avatar
Your looking at a substantial task to wind an anode choke, As for you question about core gap and winding you need to know what type of core material it is and the inductance per 1000 turns, this is a common rating on cores. As for the gap it's all math dealing with the max flux density.
As for the wire size you spec it to your current and the size of the window. To save your high frequency response yes you will need some funky voodoo winding magic to cut down the capacitance.
I think the you find the max flux density the core can take then compare it to the field being set up by the coil and increase the gap tell they don't equal each other of the at least the field setup by the coil doesn't equal the saturation of the core.
But I could be wrong, there are other guru's way smarter then me that could probably give you a less confusing answer.
Nick
Old 27th February 2009, 07:17 PM   #3
smoking-amp's Avatar
It takes 1000s of turns typically for tube type impedances. And the cost of the tiny copper wire is by far the major factor these days. I suspect the cores are rather overpriced too since they are making a big deal about "audio". Many lamination manufacturers will send you a core sample or two for free for prototyping.
Ohms Law V = I R
Old 27th February 2009, 08:00 PM   #4
dsavitsk's Avatar
100H 30mA anode chokes are $56 from Electra-Print. If you are winding your own to learn, that's one thing, but if it is to save money it is likely a losing battle.
http://www.ecpaudio.com
Old 27th February 2009, 09:16 PM   #5
dshortt9's Avatar
It was both price and finding the right value. After weighing the options Electra-Print fits the bill. Thanks for the link. Lundahl 1668's are close but they spec at 25ma. and are twice the price.
Old 28th February 2009, 03:22 AM   #6
nhuwar's Avatar
Ya I would buy one. I would not want to wind one. Unless you really want to punish your self for something LOL, I don't like bleeding fingers.
Nick
Anode Follower yagas Tubes / Valves 19 20th November 2010 04:35 PM
Need advice on proper use of anode chokes. pietjers Tubes / Valves 3 5th September 2008 08:33 AM
Anode Cap Question sgerus Tubes / Valves 6 7th September 2007 05:00 PM
Anode stoppers Shoog Tubes / Valves 4 12th June 2007 06:14 PM
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Page generated in 0.08007 seconds (76.12% PHP - 23.88% MySQL) with 10 queries
