Question about a VR screen supply
Old 28th February 2009, 05:30 AM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Default Re: Thanks for hanging in there with me!
Originally posted by athos56
Ok how about this, 1k on gate and screen. Now, for the leg to the VR tubes, would you calculate the resistor like normal to set the current through the tubes?
Yep, since FET's gate does not draw a current at all.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 28th February 2009, 05:42 AM   #22
athos56 is offline athos56  United States
athos56's Avatar
Sweet, I'll give this a try.
Old 28th February 2009, 02:41 PM   #23
astouffer is offline astouffer  United States
astouffer's Avatar
I've used this design with good results for a screen grid regulator.
http://www.antiquewireless.org/otb/resto0504.htm
Old 28th February 2009, 03:09 PM   #24
Sheldon is offline Sheldon  United States
Wouldn't it be better to bias the Mosfet with a resistor from source to common, so that it always conducts some current?
Sheldon
edit: speaking of VR tube with follower here.
Question about a VR screen supplyHide this!Advertise here!
PP pentode screen supply ray_moth Tubes / Valves 43 5th August 2009 01:12 AM
Regulated screen supply mashaffer Tubes / Valves 5 3rd September 2008 03:41 AM
Maida for Screen Supply avincenty Tubes / Valves 15 20th May 2008 03:37 AM
Screen Supply For PP Amp 6f6 Tubes / Valves 4 19th November 2007 08:07 AM
screen grid decoupling cap question.... Morse Tubes / Valves 10 21st April 2003 12:29 AM
