Question about a VR screen supply
Old 27th February 2009, 08:57 PM   #11
athos56 is offline athos56  United States
athos56's Avatar
Default Spec sheet
From the looks of the spec sheet, under typical operation at 225v the draw is 5ma at idle. This is why I'm confused. Is there a lot of clipping in this typical application?
Old 27th February 2009, 09:08 PM   #12
Wavebourn is online now Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by athos56
Right, I'm not trying to argue , I'm trying to make sense of what I see and read. What operating point should you run a KT-88 screen at? What voltage and how much current will it draw? I mean I could always just hook up the UL tap and call it good, but I thought a little regulated supply would be fun to try.
I use screen voltage regulation in 3 models of my amps, both for 6L6 and GU-50. Also, I sense screen grid currents to control optical compressors. Voltage regulators are designed to supply more of current they want, while sensors are fine tuned by trimpots to start compression as soon as screen grid currents start going up sharply.
6L6 grids I run at 305V with 400V on anodes, while GU-50 screen grids I run at 275V when anode voltage is 800V. Biasing tubes I monitor cathode currents in order to set working points. Screen grid currents at idle don't matter as soon as tubes are alive.
Is there a lot of clipping, depends on conditions you are going to use your amp in: desired sound pressure, room conditions, sensitivity of speakers, max power of your amp.
The Devil is not so terrible as his math model is!
Old 27th February 2009, 09:20 PM   #13
athos56's Avatar
Cool, I guess I was just pointing out that if the current is 5ma at idle and with the max dissipation of 8w, at the voltage I was looking at the current was 26ma. It seems like the VR tubes could handle whatever happened current wise. I'm not understanding where the clipping and blown VR tubes are coming from. But I admit I am an amature with only 4 amps completed. There is always the UL taps on my OPT if I can't figure it out.
Old 27th February 2009, 09:42 PM   #14
Wavebourn's Avatar
Approaching clipping pentodes start drawing more current so if your regulator can't supply it screen grid voltages drop down abruptly that may cause different character of distortions you (or users of your amps) may not like.
Edit: VR tubes can't draw "whatever current"! And they have non-zero dynamic resistance, so a source follower keep them happy all the time: regulation depends on dynamic resistance of what supplies/draws the current VS their own dynamic resistance.
Old 27th February 2009, 09:53 PM   #15
athos56's Avatar
Ok, I'm not against a source follower, I just have to look up how to hook it up. Thanks for the replies.
Here is the page where I got the Idea, I wanted to do something similar.
Post on 807 VR screen regulator
Old 27th February 2009, 11:22 PM   #16
athos56's Avatar
Default Ok Ok
I think this is what you are talking about. Let me know if I'm wrong. If so what are the ratings I'm looking for on the Mosfet? (If I barely know whats going on in the Hollowstate world I'm even more lost in the solid state world )
Mosfet + VR tubes thread: Here
Old 28th February 2009, 01:18 AM   #17
Wavebourn's Avatar
In your case I would use something rated for 500+ volts.
irf830, for example.
Old 28th February 2009, 02:09 AM   #18
athos56's Avatar
Default A start...
Ok here is a literal translation of the post linked above, I'm going to assume that its missing something. Is this close?
Old 28th February 2009, 02:46 AM   #19
Wavebourn's Avatar
Default Re: A start...
Yes. You will need to supply current to your VR tubes of course, also a gate stopper and screen grid stoppers will be needed to avoid HF oscillations. I would start with 1K each gradually decreasing screen grid stoppers.
Old 28th February 2009, 03:06 AM   #20
athos56's Avatar
Default Thanks for hanging in there with me!
Ok how about this, 1k on gate and screen. Now, for the leg to the VR tubes, would you calculate the resistor like normal to set the current through the tubes?
Question about a VR screen supplyHide this!Advertise here!
PP pentode screen supply ray_moth Tubes / Valves 43 5th August 2009 01:12 AM
Regulated screen supply mashaffer Tubes / Valves 5 3rd September 2008 03:41 AM
Maida for Screen Supply avincenty Tubes / Valves 15 20th May 2008 03:37 AM
Screen Supply For PP Amp 6f6 Tubes / Valves 4 19th November 2007 08:07 AM
screen grid decoupling cap question.... Morse Tubes / Valves 10 21st April 2003 12:29 AM
Copyright ©1999-2017 diyAudio
