How much current will the 6as7g draw running at 150V in this circuit. I looked at the data sheets but just want to have you guyz reconfirm it for me. At around 150V it looks like it will need 20mA, is this about right?
Need to see if a 190V-0-190V 65mA transformer will do the job. Thanks
Guiness
#2 |
All depends on the value of R6.
Tim |
#3 |
R6 is 3.3K 10W resistor...
Guiness
#4 |
Guiness,
That seems about right. I know that with a 2.5K for Rk, and a plate voltage of 250V, a 6080 will draw 50mA. Probably not linear at all in that region though... |
#5 |
Um......don't forget there's voltage across the resistor too.
Ideally half. Current might be much lower than you expect, given the tube has 75V across it.Tim |
#6 | |
diyAudio Senior Member
Frank |
#7 |
I was going to use this power supply. I do like yours but it may be a bit of an overkill with the dual 6z4's. Hopefully I am not missing something
Guiness
#8 |
Just kidding but...a lot will depend on the voltage drop of your rectifier tube AND the value of the dropping resistor. Either way you're going to dissipate alot of heat with that PT. Actually, you can use that PT to feed each channel independently and still arrive at the desired B+. It wil double component count at that stage though but I would certainly prefer that to the other solution. Cheers,
Frank |
| no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? | maxpou | Solid State | 31 | 17th June 2008 04:31 PM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 04:42 AM |
| Using Ixys current regulator as current sink. | G | Solid State | 3 | 16th November 2002 10:23 AM |
| R21? and Current Source AC Current Gain | macka | Pass Labs | 9 | 20th May 2002 08:58 PM |
