diyAudio Sponsor
Old 25th February 2009, 11:00 AM   #1
halx00 is offline halx00  United Kingdom
Default transformers
Hi
I have two old transformers and wondered if I could use them in a small preamp project
Can I use the stepped down voltage from one transformer and step it up using the other?
http://i514.photobucket.com/albums/t...transfomer.jpg
Old 25th February 2009, 12:03 PM   #2
Tweeker is offline Tweeker  United States
You can. But I wouldnt bet on getting 325VDC out after filtering under load.
Be sure your foil hat has a good low impedance ground.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
FS: Transformers alexcd Swap Meet 0 19th November 2008 08:34 PM
WTB : Transformers korben69 Swap Meet 1 27th June 2008 06:05 PM
my first amp (transformers???) fitchmicah Chip Amps 5 7th January 2007 07:26 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Page generated in 0.06162 seconds (66.67% PHP - 33.33% MySQL) with 10 queries
