KT81 data sheet?
KT81 data sheet?
Old 18th April 2003, 12:13 AM   #1
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default KT81 data sheet?
I've recently acquired four very pretty Emitron (but presumably made by GEC) KT81. A search suggested that they might be equivalent to 6V6, and they look about the right size. Does anyone have a full data sheet?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th April 2003, 12:48 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default KT81.
Did you try a search on the the 7C5 yet?
It is a loktal glass-pressed base, isn't it?
EL22/M/N148
This site may be helpful, it's in German but just send me an e-mail whenever you may need translation:
KT81
Frank
Old 18th April 2003, 01:05 AM   #3
EC8010's Avatar
Default This is all very embarrassing
I took your suggestion, and looked for 7C5, which was duly quoted as 6V6 equivalent on one site. I looked further, and finally hit Billington's who said that it wasn't an equivalent to 6V6. (Didn't say it was a "potential audio type," either.) Finally, I did what I should have done in the first place, and looked it up in the Vade-Mecum. It's a KT61 equivalent on a pressed glass Loctal base.
In my defence, it's not in my GEC books!
Old 18th April 2003, 01:13 AM   #4
fdegrove's Avatar
Default KT81
LOL.
For Pete's sake don't be embarassed....this type was only produced for a couple of years.
Funny, I'm usually faster at getting results using the net than by looking for my books...
Frank
Old 18th April 2003, 01:23 AM   #5
EC8010's Avatar
Default Frank's site - a worldwide treasure
I agree. Since finding Frank's site, I don't often use my data books. However, today I needed to look up valves that just aren't on Frank's site. Gasp!
Old 18th April 2003, 09:46 AM   #6
bournville is offline bournville  United Kingdom
...I have several tube/valve manuals, some going back to WWII, and find they are often 'generous' it what they assume to be equivalents - especially in finding equivalents for KT series valves. So while they confirm that the KT81 and KT61 are electrically equivalent, some maintain that the KT61 is direct equivalent of the EL33, despite the slight difference in heater current and greater differences in electrical characteristics.
Last year I acquired an AC/DC amp which used KT71s in pp output, and one manual suggested 50L6s as equivalents, despite the differences in electrical characteristics, and not even the heater voltage and current are the same, issues which are of particular importance in AC/DC circuits.
Old 18th April 2003, 02:09 PM   #7
EC8010's Avatar
Default This is what the fuss is about
Now that I'm reasonably certain the a KT81 is electrically equivalent to a KT61, I can think about how to use them with my pair of dinky Partridge 10ka-a output transformers. The Leak TL/10 is the obvious starting point.
Old 20th April 2003, 12:07 AM   #8
EC8010's Avatar
I agree. I've never greatly trusted the "Radio Valve" manuals etc, but I've now decided that I don't trust the manufacturers' manuals either when it comes to equivalents. After all, they had a vested interest in making you "Brimarize" your kit, or use GEC valves. Sadly, the more I look at it, the worse the KT81 looks electrically. Yet it's so pretty.
Old 20th April 2003, 12:28 AM   #9
fdegrove's Avatar
Default SAME, SAME BUT DIFFERENT...
When it comes to equivalents I only trust the straight tabels of US to European and vice versa conversions.
Anything else you'd better cross-check very carefully.
Sample: 12Ax7A > ECC83 and than it goes on to the 5751...ah not quite the same thing, is it?
Caveat emptor,
P.S. Brimar? They must have come from Krypton.
Frank
Old 20th April 2003, 02:48 AM   #10
tubetvr is offline tubetvr
I dont know if this is helpful but I have a GEC valve manual from 1952 that list the KT81 as "Obsolescent type"
Summary data is give as:
Heater 6.3V 0.95A
Va max 250V
Vg2 max 250V
Gm 10.8 ma/V
Typical application
Va 250V
Vg2 250V
Ia 40mA
Ig2 7.5mA
Vg1 -4.4V
Rk 90ohm
Load impedance 6000 ohm
Output power 4.3W
I have socket diagram also but I dont have a scanner but if needed I can take digital picture of the page and post on the Web.
For me KT81 seem to be quite far away from a 6V6, the Gm is more than double and the max Va is very low. It look indeed very similar to the KT61 that is given with typical application data identical to the one given for KT81.
Regards Hans
KT81 data sheet?Hide this!Advertise here!
DSD 1751 data sheet fmak Digital Source 0 25th June 2008 11:51 AM
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
op amp/dac data sheet help Smiffy Parts 11 13th December 2004 08:14 PM
data sheet KCC Parts 5 6th January 2004 09:03 PM
