Use 2X SE output transformers fo 1x PP - diyAudio
Old 24th February 2009, 04:07 PM   #1
speaker is offline speaker  United States
speaker's Avatar
Default Use 2X SE output transformers fo 1x PP
If you took 2 identical SE transformers and tied the ground tap of one primary to the plate tap of the other, that would become the center tap. Would you then parallel the secondaries and if so, would it then drive 1/2 of the impedance of the originally specified load? (If original output impedance 8-ohm, 2 of same in parallel for 4-ohm?). Or, would there be another way to use the secondary? (In the above, the secondary would have only 1 output impedance & ground.
Just curious on this, any comments?
Old 24th February 2009, 09:25 PM   #2
jerluwoo's Avatar
It still won't work the same as a conventional pp trans since there would be no magnetic coupling between the two primaries. You will still need the 8 ohms for the tube to see the correct primary impendance. All your doing is basically making one se tranny that can deal with twice the power of a single.
Old 25th February 2009, 08:27 AM   #3
plovati is offline plovati  Italy
Seek for the "twin coupled amplifier" by Norman Crowhurst
Piergiorgio
Old 25th February 2009, 12:45 PM   #4
speaker's Avatar
That is actually what I was thinking of when I posted but that uses PP transformers to begin with. I think the first post had the answer though. I had not considered the coupling issue of the primary halves.
Old 25th February 2009, 06:03 PM   #5
Miles Prower's Avatar
Default Re: Use 2X SE output transformers fo 1x PP
That works only for air core RF xfmrs where you don't care about DC magnetization, and where the distortion from less than perfect balance is wiped out by LC tuners and/or BPFs and antenna matching networks. For audio, the results aren't going to be so swell. Best bet: if you don't need the SE OPTs, sell 'em on fraud bay and get a decent PP OPT.
There are no foxes in atheistholes
www.dolphin-hsl.com
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
2a3 output transformers.... button_fly Tubes / Valves 3 10th October 2007 02:05 PM
Output Transformers eduardio Tubes / Valves 2 13th May 2005 02:42 PM
Using output transformers on Zen Amp? G Pass Labs 14 5th November 2004 11:54 PM
Copyright 1999-2017 diyAudio
