Any of these tubes good for audio applications? Any of these tubes good for audio applications? - Page 2 - diyAudio
Old 24th February 2009, 09:54 PM   #11
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
Originally posted by mashaffer
The data sheets at this site
Link?
Old 24th February 2009, 10:03 PM   #12
mashaffer is offline mashaffer  United States
Data Sheets
Generic Signature
Old 25th February 2009, 12:09 AM   #13
Eli Duttman is offline Eli Duttman  United States
What exactly is a sweep tube?
Sweep tubes were used to power the deflection yoke mounted on the CRT's neck. A good deal of "sock" is needed to move the electron beam(s) across the phosphor face, especially at the large deflection angles that became popular. A large deflection angle allows for a shorter CRT and a cabinet that is reasonably "shallow".
2X tubes, of the same type, are needed to build a SE stereo amp.
If the mu of a triode wired 6JC6 is 40 or greater, it will serve nicely as the voltage gain device in a "flea power" SET amp. Perhaps George (Tubelab) can tell us what the mu is.
Eli D.
Old 25th February 2009, 12:28 AM   #14
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
The 3 "sweep" tubes. What exactly is a sweep tube?
"Sweep" tubes were originally designed to "sweep" the electron beam back and forth across the face of a TV picture tube to paint the picture. It is also responsible for generating the high voltage needed to operate the picture tube using a step up transformer known as a flyback. Early sweep tubes were made out of audio tubes. One of the first was the 6BG6 which was nothing more than a 6L6GB with the plate wired to a cap on the top of the tube to better deal with the high voltages.
As TV sets got bigger, more power was needed to sweep the beam across a larger screen, and more power was needed to generate the higher voltages to light up the bigger screen. When color TV came out even more power was needed. The poor sweep tube operates at full power all of the time. "Turning down the volume" on the sweep will make the picture smaller.
The sweep tube evolved into a purpose designed power tube able to run at full power for hours at a time 7 days a week. The 3 type numbers that you have are from the end of the vacuum tube TV era and are some hefty tubes.
During the CB radio craze of the late 1970's people figured out how to make some big booster amplifiers (highly illegal) using as many as 10 of these tubes wired together. These amplifiers ran the tubes far above the published ratings leading to short tube life. This alone has resulted in stratospheric prices and limited supply of some sweep tubes.
Several audio engineers, experimenters and commercial manufacturers (including McIntosh) figured out that sweep tubes could be used to make some serious audio amplifiers. Most sweep tubes can be used to make push pull amplifiers and power levels of 50 to 150 watts can be often extracted from a pair of sweep tubes. Some sweep tubes will work in a single ended amp, and some will not. Unfortunately the only way to find out is to actually hook them up and test. I am not aware of any published schematics for these 3 tubes in SE mode, but they may be out there. The McIntosh MC-3500 used 8 6LQ6 tubes to crank out a very conservative 350 watts.
There are several users on this forum (including me) that have been experimenting with sweep tubes. Some of these experiments can be found in these this thread:
http://www.diyaudio.com/forums/showt...533&highlight=
More sweep tube experiments are planned when I have the time, but I tend to play with tubes at the other end of the price spectrum. Some sweep tubes never gained popularity with the linear amplifier crowd, and were either not popular in the TV world (supply exceeded the demand), or extremely popular (millions made). These can be found in the tube sellers bargain sales for very low prices (sometimes $1 each). I have a few used tubes of the types you have, but I may never experiment with them due to their high prices.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th February 2009, 12:34 AM   #15
Don't know yet, but there are 4 of them sitting here in a large box full of tubes that will get evaluated as driver tubes. I have a rather large list of tubes to test, so I can't say when these will get done.
Any of these tubes good for audio applications?Hide this!Advertise here!
Best BJT for audio applications Aiace Solid State 7 28th March 2009 07:33 AM
Audio applications of sweep tubes and ratings weinstro Tubes / Valves 8 29th February 2008 07:07 PM
Book FS: Audio IC Op-Amp Applications by Jung davidhs Swap Meet 2 15th July 2007 03:21 PM
Books on electronics in audio applications: recommendations? LowRedMoon Parts 3 5th January 2006 06:56 AM
Copyright ©1999-2017 diyAudio
