diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Any of these tubes good for audio applications? (http://www.diyaudio.com/forums/tubes-valves/139159-any-these-tubes-good-audio-applications.html)
Binaural 23rd February 2009 06:31 PM
I recently found a box of old Realistic Lifetime tubes in a closet. I haven't heard of any of the tube types in the box and was hoping someone here has heard of one, some, or all of them. Basically I'm wondering what they were used for and what application are they best suited for and finally if I could use them for any DIY project whether it be a pre or power amp or whatever really. Here's a list of what I've found:
1X 6KD6
1X 21GY5
1X 6JS6B
1X 6LQ6 (6JE6C)
1X 17JZ8
1X 6Z10 (6J10)
1X 1K3
1X 10JY8
1X 4EH7
1X 6JU8
1X 4EJ7
1X 10KR8
1X 12BV7 (12BY7A)
2X 6JC6
2X 6HG5 (6AQ5A)
3X 6GH8A
Again, any information is usefu. Thanks.
Colt45 23rd February 2009 07:48 PM
The 1K3 is useless, the others are only limited by imagination.
Eli Duttman 24th February 2009 12:21 AM
Re: Any of these tubes good for audio applications?
1X 6KD6
1X 21GY5
1X 6JS6B
1X 6LQ6 (6JE6C)
1X 17JZ8
1X 6Z10 (6J10)
1X 1K3
1X 10JY8
1X 4EH7
1X 6JU8
1X 4EJ7
1X 10KR8
1X 12BV7 (12BY7A)
2X 6JC6
2X 6HG5 (6AQ5A)
3X 6GH8A
Dude,
Learn to use TDSL and peruse the data sheets for yourself.
I strongly suspect those tubes were intended to be used in a TV receiver. For instance, the 12BV7 is a video O/P type.
Off the top of my head: the 6GH8 is a pentode/triode frequently substituted for the fast disappearing 7199, the 6JU8 is a quad diode that can be used to bridge rectify LOW current supplies up to 300 VDC, and the 6HG5 appears to be a member of the 6V6 clan. IMO, the 2X 6HG5s are of obvious interest. They can be triode wired and used in an approx. 2 WPC SE amp. Look here.
smoking-amp 24th February 2009 12:46 AM
Obviously all are color TV tubes. Most of which could be used for an audio amp, but you won't find a lot of existing schematics that use them, and unlikely to find a scheme using just units off that list. So DIY is in order with these. But you better make sure they are actually working first, before commiting any money for the more expensive parts, like transformers etc.
Since the 6HG5 appear to be 6AQ5 clones, it could make sense to build something already designed around them. With only 1 or 2 quantity on the others though, it would be somewhat dubious to design around those, unless you just happen to have parts laying around to experiment. They should however be cheap to get more later though. Several tube sales are going on currently that have TV tubes for $1 each. (at that price, I would be more inclined to just select the best TV tubes suitable for a design and then just order them)
Don
Tubelab_com 24th February 2009 12:54 AM
These are all TV tubes. Many can be used in audio, but some creativity is required, schematics are not common.
The 6JS6, the 6LQ6 and the 6KD6 are sweep tubes. These can be used to build a high powered push pull amp. Unfortunately you will need 4 of the same type.
The 12BY7 is a video output pentode. They work well as an audio driver and were found in some first rate audio amps like the Citation II.
The 6HG5 / 6AQ5 is a small oudio output tube common in old radios, TV sets and a few guitar amps. They can be used in SE (1 to 2 watts) and P-P (10 watts) audio amps. They will work in most 6V6 schematics at a reduced voltage.
The 6JC6 makes a decent low level audio amp when triode wired.
As stated previousle the 6GH8 / 6EA8 can be used in several audio applications. It is most commonly found with the pentode as a voltage amp and the triode as the phase splitter.
The 1K3 is virtually useless, and the others can find use in audio with a bit more creativity. The issue that I see is that you will need at least two of a given tube for a stereo amp. You could build an SE amp with 6GH8's or 6JC6's driving 6AQ5's.
The sweep tubes bring good money on Ebay. The funds could be used for transformers.
Apex Jr 24th February 2009 01:37 AM
The 6JS6B and 6LQ6/6JE6C can be used in Ham Radio Linears
since there sweep tube and have been adapted .....
The 12BY7 has been used in audio and is about a $15.00 tube
Your 6GH8 just missed it, awhile back there was a project
using the 5GH8's
Rest ... Good luck...
Steve @ Apex Jr.
richwalters 24th February 2009 04:27 AM
The 12BV7 is a high flyer. Don't bin it as numbers are getting scarce and one can make a dammned good driver stage from it in triode config. For decades it is one or my favourite audio tubes.
richy
dsavitsk 24th February 2009 05:16 AM
2 Attachment(s)
Originally posted by Colt45
The 1K3 is useless
You could use it to make a shunt regulator for a highish voltage line stage -- something like a 12b4 with a CCS on its plate. It is higher voltage than most glow tubes, won't (?) oscillate when bypassed like a glow tube.
Edit, it has lousy impedance specs -- an order of magnitude worse than a glow tube. Still, with constant current it could work.
Binaural 24th February 2009 06:39 PM
Eli,
I do have TDSL, and went through and looked at all these tubes, but being somewhat of a beginner when it comes to tubes and a total novice when it comes to designing tube circuits, i only see the pinout and type of tube as well as some stats. Most of the links don't work and the datasheets are still a bit foreign to me.
The 3 tubes that intrigued me the most were the 3 largest. 6kd6, 6lq6 and the 6js6b. The 3 "sweep" tubes. What exactly is a sweep tube? Could they be used in a single ended or push pull audio amplifier? If not what would warrant a tube for these applications? I'm doing as much research into tube "technology" i quote it because i know it's nothing new, but it's definitely new to me and fascinates me. I also like to hear people's differing opinions on circuits, tubes etc. Hence this thread!
mashaffer 24th February 2009 09:50 PM
Binaural;
The data sheets at this site are more complete and easier to understand IMHO. You can see characteristic curves for most and details of maximum values as well as typical applications. In some cases you will have to use your imagination to interpret the data for some tubes intended for unusual service but careful study of the data sheets will get you started in the right direction and then you can ask specific questions based on what you see there.
Hope this helps.
Copyright 1999-2017 diyAudio
