| diyAudio Sponsor | ||
Building a pair of SimpleSE amps and have the first working. I am using an Allied power trans and Triad choke, with Edcor GXSE opt's. I have Genalex Gold Lion Kt88's and Kt77's and am using the Dayton film and foil cap.I dont yet have my HVAC motor run caps (to arrive Friday).
As speakers I have the Emerald Physics CS2 clone. With only about an hour on each set of tubes the KT77/EL34 sounds great on the tweeters. (BMS 4552ND and DDS waveguide). The KT88's dont have the grunt for the four Alpha 15a's,(running UL) but as stated, I dont have the run caps yet, I haven't tried s/s rectifiers yet and who-knows maybe the Edcors middle series wont have the low end grunt. Later I might try the CXSE series or Hammond 1628, but George is working on a push/pull which should have more power. A great amp for a newbie tube builder like me. |
| SimpleSE PCB out of stock | tubelab.com | Tubes / Valves | 29 | 27th October 2009 08:18 AM |
| Another TubeLab SimpleSE Build | nic6paul | Tubes / Valves | 91 | 13th June 2009 03:16 AM |
| 6V6GT in the SimpleSE | w5jag | Tubes / Valves | 10 | 2nd May 2008 02:44 AM |
| 3K or 5K OPT in EL35 SimpleSE? | cbutterworth | Tubes / Valves | 2 | 18th January 2008 02:10 AM |
| SimpleSE and me | allyourzigg | Tubes / Valves | 8 | 1st August 2007 02:44 AM |
| Page generated in 0.06795 seconds (71.22% PHP - 28.78% MySQL) with 10 queries |
