KT88 cathode resistors? - diyAudio
Old 22nd February 2009, 09:05 PM   #1
Default KT88 cathode resistors?
Hi all
I need some metal film power resistors to fix an amp for a friend of mine.
The amp is an airtight ATM 2 and the resistors I need to replace are the cathode resistors (for KT88s). They look like about 2W or maybe 3W resistors. But the brand - I don't know what they are - have you guys seen them before?
They are labelled as 10R (and the good ones measure as 10.4R) with a logo "RW-2" and then the value (10R) and underneath that "L609".
Also would anyone know where to buy some of them? I know that I could just get some alternates from mouser (and thats what I may end up doing) but I would like to keep this amp as "original" as possible.
TIA for your help...
Fran
Old 22nd February 2009, 09:21 PM   #2
azazello's Avatar
http://www.hificollective.co.uk/componentshome.html
/maybe similar, but for Hi-Fi/
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 22nd February 2009, 09:27 PM   #3
kmaier is offline kmaier  United States
kmaier's Avatar
Possibly these:
www.koaspeer.com/pdfs/res61.pdf
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 22nd February 2009, 10:06 PM   #4
Coulomb is offline Coulomb  England
Coulomb's Avatar
Here is your resistor, a Vishay Deloric RW 5Watt
RW74U10R0FB12
Mouser
Anthony
I like to stay current!
Old 22nd February 2009, 11:15 PM   #5
Ok, I found it! kmeier had it right.......
http://www.koaspeer.com/pdfs/res61.pdf
Unfortunately I don't think mouser stock them.......
Does anyone know who stocks them? I've emailed partsconnexion to see if they do.
Thanks to all so far...
Fran
Old 22nd February 2009, 11:50 PM   #6
Coulomb's Avatar
Go to this website and enter your part number
FindChips
Anthony
Cathode feedback on Mikael's SE KT88? porkchop61 Tubes / Valves 0 21st July 2008 04:19 PM
Light bulbs as cathode resistors? Jeb-D. Tubes / Valves 19 28th June 2008 01:11 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Cathode Resistors garrett hongo Parts 4 16th November 2007 06:15 PM
Resistors on DHT Cathode dsavitsk Tubes / Valves 4 10th October 2006 10:05 AM
Copyright 1999-2017 diyAudio
