A directly heated triode or Pentode SE amp on a Budget
Old 7th March 2009, 12:12 PM   #21
revintage is offline revintage
Do you mean a Tubelab PowerDrive?
Its the same topology around the SF.
Noticed Millets site is down. Here are the 813 triodecurves I found elsewhere:
Old 7th March 2009, 10:13 PM   #22
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
Originally posted by Bandersnatch
Nothing yet published on it, but drawing one is straightforward. 6CL6 is another fine tube; no characteristic pushed to the limit and easy to implement.
cheers,
Douglas
Um well OK. Do you think you could draw one for me/others? I'm not understanding what you mean
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 7th March 2009, 10:44 PM   #23
Sheldon is offline Sheldon  United States
I think he means something like this: http://www.tube-town.net/diy/sv-amp/svamp02.gif
Old 7th March 2009, 11:02 PM   #24
Bandersnatch is offline Bandersnatch  United States
That's about it...
cheers,
Douglas
the Tnuctipun will return
Old 8th March 2009, 12:16 AM   #25
rcavictim's Avatar
That's about it...
cheers,
Douglas
Thank you Sheldon.
Doug,
That is simply a cathode follower. No wonder I was confused. It would have helped enormously if you could have simply said so. That term does not appear in any of your posts. Instead you start introducing cascode pairs of FETs and how a simple 12HL7 can be used instead. Instead of what? One of the FETs, both of the FET's? No hint of the circuit being described.
A directly heated triode or Pentode SE amp on a BudgetHide this!Advertise here!
a directly heated monkey? Rocky Tubes / Valves 42 5th May 2006 02:04 AM
Directly heated cathodes, but why? Hesky Tubes / Valves 12 8th June 2004 01:18 AM
