Annoying high frequency ringing from my 832 tube amp - Page 2 - diyAudio
Old 6th March 2009, 08:24 PM   #11
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
What a pain in the *** this was. As I recall, when I built this amp I set the power transformer on my bench and started attaching parts to it (not really), so I was forced to remove a significant amount of the amp in order to get to the screws and remove the bell end. Once the bell end was off I mixed up enough 2 part epoxy to coat the inside of the bell end with about a 1/16" thick layer. I reassembled the amp and the ringing is gone. My amp is not as quiet as can be.
Thanks for the suggestions.
By the way, Hammond wanted me to send the transformer back to them for evaluation before saying if they would replace it or not. Not worth the expense for the risk.
Old 6th March 2009, 10:58 PM   #12
At least your effort wasn't wasted.
I've bought my last Hammond transformer. That's it for me.
Old 6th March 2009, 11:41 PM   #13
kuroguy's Avatar
Make that "My amp is now as quiet as can be."
Old 7th March 2009, 12:04 AM   #14
rcavictim's Avatar
Thumbs down The new Hammond
Perhaps this is what that butt ugly knockout plug is for on the new series Hammond xfmers. You remove it to let the annoying noise spill out.
The older X-series end bells were IMO far more attractive. How many requests did they get from electricians that wanted to install BX cable or conduit on their tube utput xfmers anyhow to make such an across the board change????? Doofus's and ijits!
Fred, why did you have to grow old, relax supervision of the company and then die? You are missed!
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency transformers ohuzoor Parts 3 13th April 2009 01:15 AM
High frequency high voltage oscillator - help! gentlevoice Analog Line Level 8 10th September 2008 02:52 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
Copyright 1999-2017 diyAudio
