A question about audio interconnects for the ones here with such knowledge.
Old 21st February 2009, 09:30 PM   #1
G is offline G  United States
G's Avatar
Default A question about audio interconnects for the ones here with such knowledge.
Is 67pF per meter @1Khz a good for a analog interconnect? Thanks.
Gavin
Old 22nd February 2009, 06:40 PM   #2
Eli Duttman is offline Eli Duttman  United States
Gavin,
Nobody else has spoken up. So, I'll take a shot at your question.
67 pF./M. is roughly 20 pF./ft. That's quite satisfactory. Sight unseen, that low number suggests unshielded construction. Unshielded cables are not satisfactory for long runs or in high EMI/RFI level environments.
Eli D.
Old 24th February 2009, 03:25 AM   #3
Gordy is offline Gordy  United Kingdom
I guess that it is a balance of virtues (or a balance of compromises) when it comes to cales and impedance. If you want to go co-axial then RG59 is about the capacitance level that you stated.
Old 24th February 2009, 03:54 AM   #4
HK26147 is offline HK26147  United States
This might help:
http://www.sengpielaudio.com/calculator-cable.htm
A question about audio interconnects for the ones here with such knowledge.Hide this!Advertise here!
Interconnects question. merlin2069er Analog Line Level 7 20th February 2009 02:07 PM
Knowledge needed. Need answer to basic yet puzzling question. G Tubes / Valves 6 25th December 2004 06:17 PM
Charles Hansen measures audio interconnects? Steve Eddy Everything Else 1 21st June 2004 07:03 AM
How to make Audio and Video Interconnects Bthompson Everything Else 0 20th April 2003 11:13 PM
