Hi-end GM70 amplifier with only 2 stages
Old 21st February 2009, 12:13 PM   #1
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign Hi-end GM70 amplifier with only 2 stages
Default Hi-end GM70 amplifier with only 2 stages
As suggested by George in the other forum:
Andrea, you have the irons, you have most of the circuit needs, why don't you try the promising D3a - Gm70 2stage SE solution, D3a can do the trick also with 1:1 interstage...
George
I have started the measurements of this configuration using Bartolucci interstage 1:1 48H INT8C and Tango X-10S (soon I will test Bartolucci OPT)
http://www.audiodesignguide.com/Clau..._8ohm_90mA.gif
Very good frequency band 10Hz at -3db and 22KHz at -1db
Power about 16.5W on 8ohm with only an input of 0.7Vrms
Soon complete schematic.
Old 21st February 2009, 12:56 PM   #2
Banned
This is the schematic.
It is necessary use DC filaments for the GM70 to skip ac noise.
Old 21st February 2009, 01:43 PM   #3
aroS3 is offline aroS3  Greece
Send a message via MSN to aroS3
Default Re: Hi-end GM70 amplifier with only 2 stages
George
Very good results Andrea. I'm glad that worked this way. Looking forward for different OPTs comparison and sonic results also.
George
Old 21st February 2009, 05:42 PM   #4
Gluca is offline Gluca  Italy
Gluca's Avatar
I'd suggest to stack the supplies and direct couple the tubes (getting rid of the interstage). Been there wit GM70, you will be surprised.
Gianluca
Old 21st February 2009, 05:54 PM   #5
Gianluca
Gianluca tell us some more details about your results, measurements, operating points e.t.c
Old 21st February 2009, 06:21 PM   #6
Banned
Today first comparation test with 4 my friends:
1) 6HV5A+845 with new INT8C + Tango X-10F
2) D3A+GM70 copper with orig. INT8C + Tango X-10F
3 on 4 prefer the second amplifier.
GM70 graphite give a bad result when compared to copper type.
Old 21st February 2009, 06:41 PM   #7
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Hi-end GM70 amplifier with only 2 stages Hi-end GM70 amplifier with only 2 stages
Then maybe you should do some adjustments...there are no reason that the inferior("copper") tube should do better, just because it's rarer and more expensive...
Arne K
Don't believe everything you think...
Old 21st February 2009, 06:44 PM   #8
serph1nia is offline serph1nia  Netherlands
Do you think an amplifier like this will still be worth it on high sensitivity speakers (97db+)? Or is it power vs. quality?
I'm looking for a SET that can do rock, house and heavy orchestra.
What is the difference between your 845 amplifier and this one, instead of saying gm70 is better. Maybe include a 300b to the comparison.
I enjoy your worjk very much and I'm learning alot!
Old 21st February 2009, 07:15 PM   #9
moray james is offline moray james  Canada
Default Have a look at these.....
http://www.diyaudio.com/forums/showt...threadid=42259
http://www.dddac.de/op06.htm
moray james
Old 21st February 2009, 10:53 PM   #10
JoshK is offline JoshK  Canada
Gianluca
Surprised good or surprised bad?
Hi-end GM70 amplifier with only 2 stagesHide this!Advertise here!
want to do PP-GM70 day Tubes / Valves 79 10th October 2011 06:30 PM
GM70 SET direct coupled 2x30W monoblock amplifier noyan Swap Meet 3 15th February 2009 03:48 PM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
Another Gm70 amp !! HFGuy Tubes / Valves 4 8th July 2005 08:41 PM
Amplifier Question - Predriver stages thylantyr Solid State 11 27th June 2005 08:44 PM
Copyright ©1999-2017 diyAudio
