| diyAudio Sponsor | ||
Long time ago, I heard nothing was better than ceramics. Some military NOS tube sockets are made from ceramics/porcelain.
Nowadays, most expensive sockets are made from Teflon. Even porcelain is not a standard. And there is a brown material like plastic that is even more expensive than porcelain. Anybody knows about socket material quality or characteristics? I have some porcelain sockets that I may or may not use in my project, depending on the information. |
#2 |
From what I know teflon is one of the highest grade insulators available, but for the money I've seen these sockets advertised for it's not worth it. Also, porcelain is a high quality insulator all in itself and quite affordable, so I stick to it. As for the other sockets you mentioned, they are most like NOS bakelite sockets, please correct me if I'm wrong on this. Overall, ceramic is the way to go.
#3 |
Bakelite! Yes, that's what they call it. Some audiophiles tried to convince me that bakelites are better than ceramics. They talked about distortion (or harmonics) created by the ceramics.
I got the feeling that the ceramics were okay, or at least not so bad that I have to buy new sockets to replace something I already have at hand. Thanks, I think I will solder the ceramics tonight... |
#4 |
diyAudio Senior Member
All the bakelite sickets I've seen so far were dark black. The brownish one are likely amphenol, a plastic. More important than the insulator material is the quality of the contacts IMHO, at audio frequencies that is. Cheers,
Frank |
#5 |
Amphenol is a brand, not a plastic. You're probably thinking of phenolic.
The best material is indeed ceramic. Temperature resistant, low loss at RF, great mechanicals. Teflon is an excellent dielectric, but soft and not as refractory. Bakelite is... nostalgic. Phenolic is the same stuff used to make cheap fishplate circuit boards. I'd agree with Frank, though- quality of contacts is the number one consideration in specifying a socket. As a side note, there was an amp manufacturer who made a big deal out of eliminating the sockets and soldering in their output tubes. Of course, what went unsaid was that the satellite circuit board to hold the output tubes was connected to the rest of the circuit by, yes, you guessed it, a connector.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#6 |
Contacts: Some modern sockets have very poor contacts, but so long as your valves don't go in and out like a sailor on shore leave, this shouldn't be too much of a problem. Johnson made sockets with superb contacts.
Insulation: Brown and black phenolic sockets are leaky and can allow noise currents to flow from anode to grid. Ceramic and PTFE are measurably close to perfect.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#7 | ||
Sound was nothing to write home about anyway and engineering too shortsighted to be worth mentioning... Quote:
I personally go for PTFE sockets (the British army ones) for small signal apps and ceramic for power apps, contact quality being good on both counts that is. Cheers,
Frank |
#8 |
Account Disabled
hi all,
i think the most important is the contact pins that can best contact or not. I agree that china made is not ggod. If U want I make a choose, i will choose NOS EF Johnson ceramic one or expensive Japan made telfon/The high stardard telfon & the pin use solid copper to raw the sharp with 24K gold plate. the pins was a cone sharp. I feel that this is good but $$$$$$$. thanks Thomas
#9 |
I occasionally use ceramics, but mainly use old NOS bakelite sockets, simply because I have them available. I've never had a problem with the quality of the contacts, but one rider I would say that if you are using these type of sockets in experimental circuits using octals or loctals in which you constantly change the tubes, they are physically more likely to break down.
I used to have some old computer panels from an early tube computer, and these had double triode type tubes soldered directly into the panels to improve electrical contacts. |
#10 |
Account Disabled
hi bournville,
I think U say the old tube computer is the old we or hp old computer or the old telephone building or cinema use. Certainly they were very good. i give U see one item for PX25 use. Its made by in company call Emerson Radio & photograph corp. Its prefect contact. i & my friend like it most. As U said U use NOS socket. They were best, I feel that the quatity is better than the new one. thanks Thomas |
| Which socket for a 5Y3?? | Richard Ellis | Tubes / Valves | 2 | 11th November 2008 05:41 PM |
| 8 Pin DIP Socket Help Needed | KP11520 | Chip Amps | 15 | 25th August 2007 05:52 PM |
| Help on tube socket | dung0981 | Tubes / Valves | 6 | 5th August 2006 09:31 AM |
| what rca socket do you think is best?? | wuffer | Parts | 24 | 26th May 2006 12:35 AM |
| Op-Amp Socket | justpoor | Digital Source | 3 | 8th March 2005 10:23 PM |
| Page generated in 0.16272 seconds (62.22% PHP - 37.78% MySQL) with 11 queries |
