diyAudio Sponsor
Old 20th February 2009, 01:40 AM   #1
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Default Edcor CXSE25-8-5K Dimensions
Does anyone with one of these transformers know the actual external dimensions? The dimensions on the Edcor website conflict with their own drawing of that bobbin.
I'm trying to check for fitment.
Thanks,
Russ
Old 20th February 2009, 01:48 AM   #2
Geek's Avatar
If no one here has one to measure, you can ask for the dimensions exactly through their support forum:
http://www.audiotransformers.net/forum/index.php
Cheers!
Old 20th February 2009, 02:03 AM   #3
tubelab.com's Avatar
I have a pair of the very first ones. They came in "pimp my ride" metallic blue. They are 3 7/8 inches wide, 4 1/2 inches deep, and 4 13/16 tall. The mounting hole pattern is 3 by 3 3/8 inches.
They have changed the color, but I doubt that they changed the size.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 20th February 2009, 08:19 PM   #4
Sal Brisindi's Avatar
Here you go.
Sal
Old 20th February 2009, 08:51 PM   #5
Ty_Bower's Avatar
I've got some twenty-five watt CXPP, but no CXSE. They sure are a purdy shade of blue.
Click the image to open in full size. Click the image to open in full size.
Old 21st February 2009, 12:04 AM   #6
nhuwar is offline nhuwar  United States
nhuwar's Avatar
PIMP MY RIDE METALLIC BLUE, thats my favorite color.
Sorry off topic LOL
Old 21st February 2009, 12:45 AM   #7
rknize's Avatar
Originally posted by Sal Brisindi
Here you go.
Sal
Yeah, look at those dimensions and then click on the PDF. I started doing chassis layout and realized that those dimensions didn't jive with what I have read about these transformers on George's site when compared to what I am used to (Hammonds). They seemed too big.
The last couple of batches of Hammond power transformers have been very disappointing and I don't plan to buy any more of them. They are running hotter than ever (both temperature and voltage), which screams to me that they are cheaping-out on windings. Given what they cost, it's more than a bit sad.
I'm going to build an all-Edcor Simple SE and in fact I just put in the order with Edcor (they were very friendly and helpful). I've been searching for a simple SE design and George certainly hands this one over on a silver platter with his handy PCBs and super-ultra-detailed instructions. I've built more than a few PP amps but I have never manged to finish an SE design. I am sort of "over" the whole ultra-high-wattage thing, so building an 845 SE amp doesn't have to be my first anymore.
Old 21st February 2009, 12:45 AM   #8
rknize's Avatar
Thanks...that jives more closely to the PDF, which is what I ended up using.
Russ
Old 21st February 2009, 03:26 AM   #9
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
They are big. Infact I would consider them overkill unless your planning to do a kt88, kt90 or 6550 simple SE optimized for pentode or UL mode.
I recently had them make me some custom OPT's and PT's for my 6c33c SE. Even full power (16Wrms) at 20Hz, the CXSE doesn't seem the slightest bit fatigued. I'm running the power transformer at the VA that I specified and it doesn't buzz and barley gets warmer than room temp. That's made in America for you, boy.
This is one happy customer. Edcor does not skimp on materials and the pricing is very easy on the pocket book. They are no longer "pimp my ride" metallic blue, the are now more of a smurf blue, maybe a little darker
Old 21st February 2009, 03:45 AM   #10
rknize's Avatar
Bring-up/break-in will happen with Chinese EL34s. After that I was planning to try everything I can throw at it from my stash, including Tungsol 6550 re-issues, SED KT-88s, KT-90s. I also have a pair of JJ 6L6GCs with no home. Then there are the 8417s,,,
I wanted to make sure the transformers could take a thrashing.
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 02:16 AM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 05:27 AM
Edcor CXSE25-8-4K vs Hammond 1628SEA? porkchop61 Tubes / Valves 3 25th July 2006 11:51 AM
Edcor P-P Transformers wrenchone Tubes / Valves 10 30th June 2006 07:01 PM
Page generated in 0.10786 seconds (81.45% PHP - 18.55% MySQL) with 11 queries
