diyAudio Sponsor
Old 19th February 2009, 05:15 PM   #1
iain42 is offline iain42  United States
iain42's Avatar
Default scott 299D output transformers?
I am trying to find vintage scott transformers for the 299D. It uses a pair of 7591 tubes per channel. Are there any new production transformers that I can use for this old Scott? I'd prefer original but I may not be able to find them at a decent price. Any advice much appreciated. Thanks.
Old 19th February 2009, 09:31 PM   #2
hey-Hey!!!,
See Heyboer in MI for a new Dynaco A420. 6k6 a-a and sized like the A470 of the St.70. A step up they could also wind would be the Peerless S230.
cheers,
Douglas
the Tnuctipun will return
Old 19th February 2009, 10:09 PM   #3
iain42's Avatar
Originally posted by Bandersnatch
hey-Hey!!!,
cheers,
Douglas
I like the peerless wind idea. When I talk to Heyboer what kind of specs do I need to provide?
Thanks,
Iain
Old 19th February 2009, 10:26 PM   #4
hey-Hey!!!,
You have them ask me for the engineering sample. I've had them make copies of the S265Q and S271S. The S230 is waiting for an appropriate project...if yours comes up before mine, that's OK with me...
cheers,
Douglas
Old 20th February 2009, 12:02 AM   #5
Iain,
Doug has clued you in about Heyboer. If the expense turns out to be more than your budget can bear, check out the Edcor CXPP60-MS-6.6K. At $70.30 each, the price is modest. The 60 W. rating means you have plenty of magnetic headroom, to accomodate the low freq. error correction signal associated with loop NFB. In addition, Edcor O/P "iron" has ultralinear taps, which would allow you to experiment with that mode.
Eli D.
Old 20th February 2009, 02:50 AM   #6
iain42's Avatar
hey-Hey!!!,
cheers,
Douglas
Interesting. So do you think this would be a step up or at least equivalent to the original Scott? Thanks for offering I may take you up on it. I'm almost hate to ask but what do you think the ballpark price could be?
Old 20th February 2009, 02:56 AM   #7
iain42's Avatar
Originally posted by Eli Duttman
Iain,
I asked in the previous post about price which I am curious about.
The edcor was mentioned to me by someone else as well. The price is wonderful. Do you think performance would be ok? I also wonder if it the peerlees and edcore would fit on the chasis. I'll take some measurements. I'm not much of an experimentor as I know just enough to be dangerous.
I am nervous about substituting the original transformers but I just can't find them anywhere.
thanks for the info
Old 20th February 2009, 04:17 PM   #8
HollowState's Avatar
Suitable transformers often show up on eBay. There's two from a Fisher 400 series that used 7868 tubes which are similar to 7591's, but with a different base.
http://cgi.ebay.com/Fisher-400-recei...1%7C240%3A1318
http://cgi.ebay.com/FISHER-400-outpu...1%7C240%3A1318
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 20th February 2009, 05:37 PM   #9
iain42's Avatar
This is the only forum that has given me alternatives to the original scott transformers. So now I can choose between Peerless custom, Edcor, and Fisher 400. I noticed the 400 is rated at 30 at full power will that be a problem since the Scott is rated at 34wpc?
Thank you so much everyone. This forum is great.
Old 20th February 2009, 06:23 PM   #10
No it won't. A ± of a couple of watts is negligible since it's a general specification. Not all eBay sellers get their numbers perfectly correct anyway. And for that matter you could even use Fisher 500 series OPTs. They used 7591's if I'm not mistaken.
(edited for spelling)
Victor
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Scott LK72 output transformer quality ? ashok Tubes / Valves 4 11th February 2004 09:52 AM
Which is the best for output transformers AD1865 Tubes / Valves 32 28th October 2003 09:17 PM
2 output transformers in 1 amp? PeteMcK Tubes / Valves 2 12th February 2003 12:47 AM
Page generated in 0.11859 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
