| diyAudio Sponsor | ||
I was wondering about the relative quality (fidelity) of the tube amps fitted to Jap tape recorders of the 60's. Eg Sony, Akai, etc. I have an opportunity to buy a "dead" RTR - ie the tape mechanicals are non-functional but the amp is intact. Is it worth attempting restoration? replacing the passive components? Doug PS I'd be transplanting the whole thing onto a new chassis, a la Bottlehead style.
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#2 |
I once owned an Akai M7 (or M8?) which was basically a copy of a Roberts. As I remember, the electronics weren't bad if you want a mike or line amp. But remember, they contain equalization circuitry you'll have to deal with. If you can find an Ampex 600 series, they are far superior. The Akai transport is a real dog. It suffers from high flutter by way of a cheesy felt clutch in the supply turntable that cogs.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 |
I built the first tube amp shown at http://buffalo.nas-central.org/index...e=User:Kuroguy using parts I scavenged from an old Sony R2R recorder. I only had to scavenge a chassis and purchase a few capacitors and resistors. Old tube reel to reels are chock full of useful stuff. You may not find the highest qualitty parts, but free is free.
#5 |
I have several of the amps from the AKAI/Roberts RTR's (3 pairs right now). These wonderful little SET amps can be had for cheap on geEdBay and are readily available. You can get them going with just few mods, or tear them down and rebuild...either way they are pretty nice...and the transformers seem to have about 100 taps (not really...but alot of taps). They can yield a wealth of nice parts for building your own little flea power amps....or the beginning of something bigger.
Wayne
"I am always doing that which I cannot do, in order that I may learn how to do it" |
#6 | |
frugal-phile(tm)
For hifi use the amps need complete reworking, but i figure a fine set of monoblocks can come of them (EF86>EL84). Size of the OPTs will limit bass somewhat. The highest quality R-R iron i've seen are in the Sony TapeCorder 500. They come with a beefy mains trafo, and a set of nice TamRadio (Tamura) OPTs. Lots of interesting resistors, and a shock mounted double 9 pin mounting. The amp is 6AU6 > 6AQ5, but any combo with 6V6/EL84/6AQ5 could be subbed. The OPTs have a 600 ohm tap which might be a good way to feed SS (sub)woofer amps. The big bonus with these R-R is that they also come with a pair of the Coral holey basket 103As (8 ohm) -- they are usually worth the entry fee, and the amp parts come along for free. dave dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Let's talk vintage Soundcraftsmen PCR-800 amps | VintageDave | Solid State | 0 | 10th February 2008 06:31 PM |
| What vintage tube books do you own? | fernando_g | Tubes / Valves | 24 | 23rd November 2007 05:12 PM |
| vintage tube amp repair help | adason | Tubes / Valves | 25 | 10th December 2006 09:48 PM |
| Tons of electronics, vintage speakers, amps, and parts etc.. 70 items + | transducergeek | Swap Meet | 1 | 14th August 2006 06:19 PM |
| Page generated in 0.08588 seconds (80.83% PHP - 19.17% MySQL) with 11 queries |
