diyAudio Sponsor
Old 18th February 2009, 03:53 PM   #1
tmatini is offline tmatini  Dubai
Default need some guidance about tube amplifiers
Dear Sir
I am an electronic engineer and have few experiences about design simple amplifiers.
Now I am going to design and implement a high quality guitar tube amplifier for myself.but I don’t know anything about tubes.
I don’t know which diagrams it has. Preamp? power amp? I don’t want to copy an implemented amplifier.i should know what is been going on
i dont know how should i begin to study and how should i proceed
Pls help me if it is possible and give me a guidline
i hope to make this thread in right position.because the masters emphasis to make it correctly.
Sincerely
Matini
Old 18th February 2009, 04:38 PM   #2
Tom Bavis's Avatar
Start with aikenamps.com
Also look at ax84.com
Old 18th February 2009, 06:07 PM   #3
Tmatini,
If I read correctly and you are serious to study about tubes and not just into making one instrument, I would suggest starting with the RCA Tube Manual - an old publication stopped about 1970 but very informative and to-the-point (available on the internet).
Otherwise I understand that 'Valve (Tube?) Amplifiers' by Morgan-Jones is an excellent book. (I do not have one myself, having studied long ago enough to be taught tube technology at varsity, but the book comes highly recommended.)
Old 18th February 2009, 06:36 PM   #4
There are a ton of books online here:
http://www.pmillett.com/technical_books_online.htm
Start by browsing the Radiotron Designer's Handbook. It is a very thorough overview of tube circuits and components, if a bit dense. Lots of books there, so perhaps something else will ring your bell too.
Morgan Jones' books are an excellent recommendation. Modern, thorough and practical. Great stuff.
-e
Old 18th February 2009, 08:26 PM   #5
Miles Prower's Avatar
Default Re: need some guidance about tube amplifiers
You already have a good basis to start. I myself began as a solid state designer, and knew virtually nothing about hollow state. Forch, the vast majority of SS know-how is directly transferable. The place to start is with the Radiotron Designer's Manual. That has ESSSSSSSSSS-loads of information concerning hollow state. Also, you might want to bookmark Steve Bench's Site (be sure to check out his technical report on loadlines) John Brosky's Site, Fred Nachbauer's Site and Tone Geeks (especially since you're interested in guitar amps) and finally, Frank's for VT spec sheets and plate characteristic charts, without which it's very difficult to design a VT circuit. Also, keep in mind that VTs are high voltage, low current (Hi-Z) devices as opposed to SS -- low voltage, high current (Lo-Z) so you'll have to pay more attention to circuit and internal capacitances. Oh, and there's no such thing as a "P-Channel" VT.
The biggest difference is that you can't design VT circuits by equation and calculator like you do with solid state. VT's are low gain devices and the characteristics of the active devices have much greater influence on circuit performance. Since the VT has components just hanging there in semi-free space, they all operate independently, and so loadlines are really your only design alternative.
There are no foxes in atheistholes
www.dolphin-hsl.com
tube newbie needs guidance MoxMonkey Tubes / Valves 20 30th June 2008 06:24 AM
why the fad with tube amplifiers? XxGoKoUxX Car Audio 20 27th February 2008 11:21 AM
DC Tube Amplifiers SY Tubes / Valves 14 1st November 2006 01:59 PM
Tube Newbee Needing Guidance TheDriver Tubes / Valves 3 10th April 2006 07:13 PM
Page generated in 0.07611 seconds (81.15% PHP - 18.85% MySQL) with 10 queries
