diyAudio Sponsor
Old 17th February 2009, 08:25 PM   #1
dognut is offline dognut  United States
Default sansui 1000a maintenance
Hello to all.I just picked up a sansui 1000a tube receiver.It is original & works.I have read on other forums & on other vintage recievers that the smart thing to do is to replace the caps & Volatage regulators & a handfull of other componets because of there age or that there prone to failure.I am not a electronics tech but can easily replace nessasary componets.Can someone tell me what usually is replaced in detail.I am going to order a schmatic & some deoxit for it tonight.Please message me at my home email add.Thanks in advance, tom
Old 18th February 2009, 12:51 AM   #2
Hi, Definately replace the 4 caps that go to the control grids of the 7591 output tubes. These are almost always bad, so to change them is a must. The other caps in the unit will also be leaky but those are the main 4 that need to be replaced.
Daniel
4-1000a se subwoofer amp nhuwar Tubes / Valves 2 7th May 2007 02:34 PM
Sound Technology ST 1000A & 1701A jblmar Solid State 11 5th March 2007 02:31 PM
Sansui 1000A output transformers JohnG Swap Meet 7 27th February 2006 10:39 PM
Sansui 1000A OPT's jlsem Tubes / Valves 1 7th July 2005 05:10 PM
ICE 1000A Q's mattiasa Class D 7 9th May 2005 06:50 AM
Page generated in 0.05998 seconds (64.40% PHP - 35.60% MySQL) with 10 queries
