| diyAudio Sponsor | ||
I need to recap my sovtek mig 60, but the 3 main caps
are 100uf/ 30uf-350v cans and i can't find replacements anywhere. Is the a suitable substitute? |
#2 | |
They list a 100uf/30uf - 475V on the Vibroworld website. Cap Page You might need to call them to confirm the order, The owner spends a lot of time on tour. |
#3 |
geez, 35 bucks a piece is pretty steep.
#4 | |
#5 |
this may be a stupid question but what would happen if i replaced them with JJ 100uf/100uf cans. i know that increases the capacitance by about 53% but what effect would this have on the rectifiers?
#6 |
What makes you think the caps need replacing in the first place?
-e |
#7 |
The power tranny is making a loud hum whem the standby is turned on and the amp puts out no sound. The noise comes from the tranformer itself! From what i read this is probably a shorted filter cap. Anyways i wanted to try replacing them to see if it helps before tracking down a new PT.
#8 |
Those caps should be for the B+, which is disabled when in standby. In standby, those caps aren't doing anything.
Is this humming transformer a new problem? Any other symptoms? Does it hum when out of standby and ready to play?
-e |
#9 |
What i mean is that the tranny makes a very loud hum when the standby is turned off and ready to play and produces no sound through the speaker. So that makes me think it is related to the B+. Sorry for the confusion.
#10 |
Could be just a noisy transformer along with another problem which is killing the output.
Know how to drain caps, handy with an ohmmeter? Got a copy of the schematic? Looked inside the chassis? Anything burned, smelling funny? It might be fun replacing the cap cans, but spending $100 on 'em just to find the O/T is shorted would diminish the euphoria. And if you are not handy enough to do some basic fault finding, you might find replacing the caps a moisture releasing experience. Ever worked on electronics? Check the simple stuff. All tubes light? Patch cable to the speaker cab is good (the Mig is a head, isn't it?) Just this weekend I opened up the belly of a guitar amp, only to find my guitar cable was shot. Usually, I am smarter than the average beer, but sometimes not...
-e |
| Active filter question | youyoung21147 | Parts | 3 | 21st May 2006 05:27 PM |
| Mains Filter (Pi) Question | weinstro | Parts | 0 | 3rd April 2004 12:49 AM |
| Question on LP filter | f.k.l.chan | Solid State | 0 | 3rd October 2003 12:12 AM |
| Pi filter question | Eccu | Solid State | 1 | 6th May 2002 03:45 PM |
| a newbie filter question | Ian | Multi-Way | 2 | 10th September 2001 12:17 AM |
| Page generated in 0.11522 seconds (71.60% PHP - 28.40% MySQL) with 10 queries |
