diyAudio Sponsor
Old 17th February 2009, 04:15 PM   #1
jeapel is offline jeapel  Canada
Default add UL tap for 125ese
hi
anyone see or try something like that on internet
or my idea (no tested) is unique?
thanks
Old 17th February 2009, 05:07 PM   #2
tubelab.com's Avatar
Yes, been done before. There was a thread on this topic about a year and a half ago. I had an output stage breadboarded before personal circumstances caused the scaling back of many of my experiments.
Adjustable distributed load discussion
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 17th February 2009, 07:47 PM   #3
thanks tubelab very good infos on the thread
my english is so so but maybe mosfet input
capacitance delay the screen current maybe
smaller delay with npn but only 300 volt max
if i understand it remains to be proved for
a good solution?
Old 17th February 2009, 08:57 PM   #4
We were also looking into seperating the AC and DC components of the signal so that UL can be used on tubes with a low screen grid voltage rating, like some TV sweep tubes. The circuit works but I never had the time to optimize it. There are mosfets that have a low "reverse transfer capacitance" which is the important spec for follower use. Fairchild FQP1N50 is one. An NPN will work too.
HAMMOND 125ESE Transformer WIRING mrhotmark Tubes / Valves 2 24th March 2010 09:30 PM
FS: Hammond 125ESE trannies RockysDad Swap Meet 0 26th November 2008 03:20 AM
Hammond 125ESE and sections mpingo Tubes / Valves 0 10th January 2008 06:41 PM
Cheap Source for Hammond 125ESE Technotinker Tubes / Valves 4 1st February 2006 12:01 PM
Hammond 125ese cheap in Europe? John007 Tubes / Valves 10 4th March 2004 08:18 PM
Page generated in 0.07709 seconds (75.57% PHP - 24.43% MySQL) with 11 queries
