Cany anyone supply any info. about this amplifier?
Old 17th February 2009, 10:03 AM   #1
OXAUDIO is offline OXAUDIO  United Kingdom
Default Cany anyone supply any info. about this amplifier?
All I konow about it is that it was made in France sometime in the 1950s. I am told it was for use with a Pathe Film projector, but there are no identifying marks, other than the number '01972' stamped on the rear chassis panel, on either the chassis or metal case(The latter is elsewhere at the moment)
Tube lineup is 2 x 6AU6(EF94), 2 x 6AQ5(EL90), 1 x 5Z4 Rectifier, plus a 'Magic Eye' indicator tube type 6AF7. I am in the process of tracing out the circuit, which seems to be fairly conventional for the time, except that one of the 6AQ5s seems to be wired as an oscillator
Inputs, each with it's own gain(volume) control, are provided for Microphone(type??) and Magnetic Pickup. A headphone socket(marked 'Casque'), and 3-way function switch, which in one position disconnects the speaker,(substituting a 3 ohm 'dummy load') are fitted
The amp runs from 110vac, the 'live' side of which is routed thru a shorting link in the Loudspeaker Socket, so that power cannot be applied without aspeaker being plugged in
Any help inpositively identifying the make, model, and, if possible, year of manufacture, would be appreciated, as would a circuit diagram, or any technical info.
Old 17th February 2009, 10:17 AM   #2
Yvesm is offline Yvesm  France
Yvesm's Avatar
Try here:
http://www.tsf-radio.org/forum/forum.php
Some of thoose french guys (like myself) can understand few english words !
And a larger pix may help.
Yves.
Old 17th February 2009, 10:48 AM   #3
Thanks for that link, Yves. I will go there and see what I can find. I posed the same question on another forum, and, to date, despite 129 people viewing it, no-one has been able to help.
AS to the picture, I can probably enlarge it, or add a different one, if need be.
Old 25th February 2009, 08:28 PM   #4
If it helps someone to identify, and perhaps provide some additional info. about the tube amp in my previous posts, I have now traced out the circuit(e & oe!!), which appears to be conventional, except that V3 is seemingly connected as an oscillator, though for what reason I know not. So far as I know the amplifier was made for use with a (?Pathe?) Home Movie Projector
Old 25th February 2009, 09:32 PM   #5
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
It is from a vintage French tape recorder.
The Devil is not so terrible as his math model is!
Old 25th February 2009, 10:12 PM   #6
Anatoly, you don't happen to know what make of French Tape Recorder, this amp. is from, do you. I ask the question because I would like to find an 'official' schematic, plus service info if possible. The Gent. who owns, and asked me to repair. it, told me it was from a movie projector, and a member of the Vintage Radio Discussion Forum here in the UK said that the Oscillator circuit around V3 was used to drive the exciter lamp for the magnetic sound track. Of course that could also be the bias/erase osc. for a tape recorder, hence the 'magic eye' indicator tube. Someone has added a modern gold plated RCA socket(J3), and fitted a 3pin microphone-type socket as a mains connector.(!!)
Old 25th February 2009, 10:16 PM   #7
Wavebourn's Avatar
My conclusion about a tape recorder was made because of mixing of signals from the output tube and from the oscillator. It is obvious.
Old 26th February 2009, 02:20 AM   #8
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
There were 16 MM projectors that could play AND RECORD on mag stripe film. Portable cameras generally didn't do sound recording... There's a photo and schematic of such a Kodak amp on my web page: http://www.audiophool.cjb.net/MadeInRoch.html
But a 6V6 oscillator was generally used to drive a 4V lamp with a photocell pickup. Or a DC lamp was used - in either case to avoid hum in the recovered audio.
Old 26th February 2009, 05:28 AM   #9
kevinkr's Avatar
Hi Tom
Your made in Rochester website is pretty cool.. Once upon a long time ago (about 1989) I owned a very pristine example of the ASP-422 which was surprisingly good sounding with the original 6DY7 output tubes in it. Gave up on it and sold it to a collector when I could not get replacement output tubes for it a couple of years later. (Pre Internet and eBay, I could probably source tubes for it today, but almost impossible at that time.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th February 2009, 02:48 PM   #10
JAN Amps is offline JAN Amps  United States
I think it is more than likely that your amp is from a projector. I own several U.S. Military 16MM projectors with tube amplifiers that were manufactured during the 1950's. They also use a 6AQ5 tube in an ocsillator circuit to drive the 6v exciter lamp for the optical (not magnetic) sound circuit.
Gary
Cany anyone supply any info. about this amplifier?Hide this!Advertise here!
choke power supply design info? dorkus Tubes / Valves 3 21st November 2007 12:24 AM
DIY AMPLIFIER KIT -- > class d? need info!! JinMTVT Solid State 6 30th April 2006 07:00 PM
More info on this amplifier? mik Solid State 2 24th May 2003 07:43 PM
Copyright ©1999-2017 diyAudio
