| diyAudio Sponsor | ||
I'm helping a friend repair a vintage guitar amp and I noticed that 550V caps are called out on the schematic. Is there a good brand that is available at a supplier like Digi-Key or one of the tube-related houses? Almost if not all the parts I've found seem to top out at 500V.
Thanks! |
#2 |
Sprague still lists an Atom electrolytic rated at 20uf@600VDC. Steve at Angela has them.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you... |
#3 |
Not cheap, but Mouser has these:
600V, 20uF 600V, 10uF 600V, 20uF Do you have room in the chassis to series connect a pair of 300 volt rated caps? Don't forget the voltage balancing resistor in parallel with each cap. |
| FS: 4 BlackGate 100uF 500V Wkz capacitors | Joseph0 | Swap Meet | 2 | 7th August 2007 03:07 AM |
| FS: 2pcs Jensen 47 + 47uF 500V | cartman | Swap Meet | 0 | 31st October 2006 03:19 PM |
| Triode connected SV6550C with 500V HT | sajti | Tubes / Valves | 9 | 18th May 2005 07:12 PM |
| Teflon 0.056uf/500V caps | JBasham | Swap Meet | 0 | 6th August 2003 07:30 PM |
| ESP P68, 500v ceramic caps? | Kram | Parts | 1 | 10th June 2003 09:00 PM |
| Page generated in 0.06989 seconds (70.43% PHP - 29.57% MySQL) with 10 queries |
