diyAudio Sponsor
Old 16th February 2009, 04:26 AM   #1
Lightbulb Just an Idea?
Ok, Well I decided to throw together a small transistor circuit, and upon finishing it, I figured maybe I can make a guitar pedal with it... then I decided to throw in some tube warmth with none other then..... A TUBE! a 12AX7 actually. After doing that I threw a few transformers on and wallah!
Now ofcourse I only did this on a schematic, havn't build anything yet. And why you ask? Well simply put - I have no idea what i'm doing
I figured there's bound to be someone on this forum who knows a thing or two about tubes and circuit's n' such. so here it is, fully open to ALL critism and idea's. Infact, I'm VERY cetain this schematic wont even function. so I'm open to any idea's that may help getting this to work, what resistance's and capacitance's and all that!
Also: Let me know what ya think of it anyway? i'm sure this has already been done 10,000 times before and in way better versions - but this one I made from scratch so i'm proud of its inability to function
Thanks,
Weston
P.S. I know! I know! 12Vdc B+, I'm still uncertain about that, I heard somewhere that the 12AX7 can run on a 12V plate. ofcourse set me straight if this is false info. (the plate is really only just to add warmth not amp (I guess?)).
Old 16th February 2009, 05:24 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
OK....yep it won't work..First off No a 12AX7 will not function with 12 VDC..tubes are high voltage devices(Read DANGEROUSLY HIGH voltages).
Second, your power supply is not even a DC supply...it is currently configured as a 'pulsing' DC supply. Your signal off the full-wave-bridge has no Capacitor to 'store' a charge when the signal waveform swings from zero to the top of the peak (12v).
Then again, transformers are rated as an RMS value. RMS means Root Mean Squared (Math term!).
If your math does not extend deep into Algebra you are going to have a tough time dechiphering this stuff.
Perhaps you heard wrong of the 12AX7 tube using 12VDC on the plate, rather the filiment voltage can be configured in either 6.3 V or 12.6 V.
Read up on this stuff first.....your schematic is way out in left field...WE can coach you on alot of stuff but you need to learn some basics first.
I would suggest some basic electronics to start you off, some power supply study, transistor operation, OP amps,Algebra for electronics & then you can turn toward towards tubes.
_____________________________________________Rick. ......
Old 16th February 2009, 05:51 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
Hi Weston,
The things that occur immediately to me are:
* The 12AX7 is not a particularly good choice if you just want warmth and not especially gain. A better choice might be a 6CG7 or 6FQ7.
* The B+ is about 1/10th of what it should be for a tube to operate properly.
* The B+ supply needs smoothing, not just rectification. That means at least a C-R-C ("pi") network.
* The tube won't do anything without a plate load, such as a resistor, between the plate (and signal take-off) and B+.
* The tube needs a grid leak resistor to ground - say 100k.
* Q1 won't operate like that because the tube grid needs to be at ground potential, so the NPN transistor won't have a voltage across it, nor would it get any current even if the grid were at a positive voltage because the grid cannot source current for the transistor. (I'm not sure what Q1 is supposed to do anyway?)
* C2 capacitance depends on the input impedance of whatever the tube is supposed to be driving. 2.2uF is a high value and suggests that the impedance of the next stage is low - probably too low to be driven from the tube's plate.
* C3 and R4 serve no purpose, as far as I can see, and they shouldn't be in there.
Just a few observations.
I suggest that you acquaint yourself with the principles of tube amplification. A good book would be the best approach, IMHO, such as Morgan Jones' excellent Valve Amplifiers. If you don't want to go to the trouble of getting a book straight off, you might get some useful information from Max Robinson's "Fun with Tubes" website.
Old 16th February 2009, 06:04 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I don't really want to point out the level of fail in this design
Maybe look at / build something similar to Fred's "real mctube". He had a good way of explaining things
http://www.dogstar.dantimax.dk/tubestuf/mctube.htm
Different pre amp idea bartek Solid State 3 25th March 2008 03:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 06:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 08:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 02:28 PM
Page generated in 0.08431 seconds (75.12% PHP - 24.88% MySQL) with 11 queries
