| diyAudio Sponsor | ||
Ok,
Can I use two rectifiers in of the same secondary of a transformer. IE. like shown in attachment? Need to flow about 250mA and my chokes can't handle it so I thought if I separated into (2) channels it will be OK. I have seen paralleled rectifier tubes but common B+ out. Is there any reason I can't do this? I might be missing something. |
#2 |
If you look one more time at your schematic you'll realise that you have drawn common B+. However I do not see that it should be a problem. You can still feed one choke per channel to bring down the current requirement on the chokes.
/Olof
I'm not allowed to do magic, union rules... |
#3 |
should be fine, but that sure is a weird way of drawing things
| Real Silly Cap vs. Cap Question | chicago_mike | Solid State | 1 | 14th November 2008 03:36 AM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| I have a real quick question... | Untouchable11 | Full Range | 9 | 9th August 2005 12:29 PM |
| Real Quick Cap question | Killjoy99 | Parts | 6 | 16th March 2004 06:39 PM |
| Real simple question | Vuamp2 | Multi-Way | 3 | 1st February 2002 10:26 AM |
| Page generated in 0.05843 seconds (78.63% PHP - 21.37% MySQL) with 11 queries |
