diyAudio Sponsor
Old 14th February 2009, 07:39 AM   #1
aardvarkash10's Avatar
Default Can you use a MOSFET as a cathodyne
splitter? Looking to deliver into a -50V biased grid on an EL36 pp - I'm a bit worried about having enough drive from a 6J7 voltage amp to 6J5 cathodyne splitter. As an option, I could go 6J7 to 6J5 two stage amplification, but I don't have space another tube to split the phases. I do have space for sand... Yeah, got MOSFET follies, and I can see the 'follower option is all good - since I'm not looking for amplification, can I take a grid from each of the Drain AND the Source of one MOSFET just like anode and cathode of a tube?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 14th February 2009, 10:55 AM   #2
So, as far as I can understand your post, you want to add a Mosfet to split the signal after a 6J7 gain stage?
What kind of Mosfet? Input resistance? Output resistance? Supply voltage?
And how many EL36 do you have to drive?
Or did I misread what you like to do with the Mosfet
How about using two BF459 transistors for full drive and split?
Old 14th February 2009, 11:58 AM   #3
SY's Avatar
If you've set the DC conditions correctly, yes. High frequency balance will not be as good as a tube because of the gate-drain capacitance.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th February 2009, 01:09 PM   #4
SY's point about capacitances is on target. A "concertina" phase splitter is a tricked out voltage follower. THE crucial parameter for a FET in voltage follower service is a low and stable reverse transfer capacitance. I recommend the ZVN0545A, for this job. While the IRFBC20 is much more robust, I'm afraid of HF roll off, given the driving 6J7.
The source sets up a few Volts below the gate. Assuming the source is at the same potential as the preceeding anode is a fair approximation. Pick a drain current (say 3 mA.) and use Ohm's Law to calculate the source to ground resistance. Symmetry requires that the same resistance and potential difference be used on the drain side. Make 1 of the loads variable, as that permits "perfection" of the 2 out of phase signals.
Eli D.
Old 14th February 2009, 05:40 PM   #5
Originally posted by Eli Duttman
.... is a tricked out voltage follower.
[/B]
Yeh, right
Old 14th February 2009, 06:42 PM   #6
hey-Hey!!!,
Use a cascode MOSFET. The input capacitance is then quite close to static, instead of varying about with drain-source voltage.
cheers,
Douglas
the Tnuctipun will return
Old 14th February 2009, 11:11 PM   #7
Default thanks guys!
yeehaa! Time to break out a power supply and do some testing in situ. THanks for your advice!
Cathodyne Questions dsavitsk Tubes / Valves 7 28th June 2009 07:36 PM
Cathodyne follower? :) mashaffer Tubes / Valves 6 16th February 2008 08:18 PM
Problem: attenuation after cathodyne and CF diegot Tubes / Valves 2 7th December 2007 06:05 AM
Cathodyne phase splitter with CCS? andrew_whitham Tubes / Valves 42 1st February 2007 09:07 PM
Problems with cathodyne tAB Tubes / Valves 11 18th January 2006 08:31 AM
Page generated in 0.09057 seconds (76.83% PHP - 23.17% MySQL) with 10 queries
