diyAudio Sponsor
Old 14th February 2009, 03:02 AM   #1
coldcathode's Avatar
Default 829B SE Comments????
Ok,
Pick it apart!!!
Old 14th February 2009, 03:06 AM   #2
Send a message via AIM to DigitalJunkie
The output of the 'SJ7 is shorted to ground! I'm assuming you meant to put a grid-leak resistor there?
Also,you might want to put a 100ohm resistor in series with the screen grid,to limit current,and help suppress any trend towards oscillation.
Just a couple things I spotted with a quick once-over.
Old 14th February 2009, 03:06 AM   #3
astouffer's Avatar
Its going to be very quiet
Old 14th February 2009, 03:12 AM   #4
rcavictim's Avatar
Is this a test? It won't play as drawn. Hint, follow the signal path from the 6SK7 plate to the 829 grid stop resistor.
Also, I think you need to put a separate grid stopper on each socket pin of the tube's two G1's.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 14th February 2009, 03:19 AM   #5
Default OOPS!!
I knew I forgot some things!!
The wife grabbed me earlier to go to the mall and I forgot where I left off translating my chicken scratch notes to a .jpg!!
Sorry, It was not a test!
Please see if I forgot anything else and tell me what you think!
Old 14th February 2009, 03:40 AM   #6
dshortt9's Avatar
829B Based Amp
Interesting info here. 829 is like 2 807's which I can find a triode graph for.
Old 14th February 2009, 03:43 AM   #7
dshortt9's Avatar
http://www.tubezone.net/pdf/807curv.pdf
Here.
Old 14th February 2009, 07:20 AM   #8
Tubes4e4's Avatar
Originally posted by dshortt9
829B Based Amp
Huh? Why not use a triode strapped 829 plot in the first place? Look here.
Tom Schlangen
If in doubt, just measure.
Old 14th February 2009, 08:49 AM   #9
Thanks Tom for the curves.
Hello Coldcathode,
why did you take 3K load impedance?
Kind regards,
Darius
Old 14th February 2009, 01:21 PM   #10
3K impededance was what I have in a nice size set of OPT's (not sure what they are from but they are pretty heavy)
They have a few taps so I will look at the new curves and see what happens.
My main question here is am I on the right track?
829B Based Amp silverchris Tubes / Valves 11 12th March 2012 10:26 AM
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
rca 829b bias ? Audioromy 828 oleslot Tubes / Valves 3 14th April 2009 02:13 PM
829B tubes for audio? webercarbmann Tubes / Valves 6 16th February 2002 10:34 PM
Page generated in 0.10693 seconds (76.20% PHP - 23.80% MySQL) with 11 queries
