| diyAudio Sponsor | ||
Got a question for the techies. On another forum, I was discussing with someone else about 300Bs (I haven't built one). Someone mentioned that the 300B was a poor audio tube because it was "slow" and had a slow rise time.
Now I am not looking for ammunition to get into a debate, that isn't interesting to me. Even though I was pretty darn sure that wasn't correct, I couldn't refute it. So it got me thinking what would be the rise time of an output tube? Isn't this a function of the load it is operating into and the time constant created by this circuit? Is rise time even a relevant concept of a tube on its own independent of the circuit it is in? I am interested in learning, Josh |
#2 |
I would guess the meaning of "slow rise time" is slew rate limited.
That would more be due to incompetent driver. Driving a 300B is not an easy task. That's my guess on that statement. Raymond. |
#3 |
Ah, here's something I know quite a bit about.
First of all, realize that this is an utterly useless topic of discussion in regards to audio amplifiers. I joke with a friend of mine that we like to design fast audio amplifiers because it lets us brag about the size of our genitalia... A possible exception is class D, but here on the tube forum, we don't talk about that much (well, people other than myself don't Now to begin answering your question. A very effective model of a tube takes into account all capacitances (including miller C!) and resistances (i.e., plate resistance in parallel with load resistance), treating the tube as, say, a CCS in parallel with this impedance. (A CCS is fair because the plate impedance is already taken into account (triode or otherwise), and because amplifiers are most often modeled as CCSs for physical as well as theoretical reasons.) So you've got the grid swinging some amount of voltage, and this causes so much change in plate current (delta Ip = delta Vg * Gm), which therefore causes the capacitance to start to change its voltage (I = C * dV/dt), and the resistor to [eventually] come to a different equilibrium voltage (V = I*R). This is why you always see those nice smooth RC exponential decays on tube-amplified square waves. By the way, this model is linear, and tubes are reasonably linear (they don't hard-saturate the same way transistors do, nor does capacitance change with voltage), so you'd expect to see the RC time constant remain constant for all signal levels -- and this is fairly well observed, rise time is actually the characteristic rise time, not a slew rate per se. So it's not a bad model at all, very simple and very useful. A more thorough model might include transit time effects and lead inductance, but these generally aren't important below 30MHz. In sub-VHF use, tubes can be considered as instantaneous transconductance amps driving the RC load I just described. Therefore, switching time is effectively proportional to R*C. In general use (like many of the circuits you see on this forum), bandwidth typically ends at 50-200kHz (higher where lower resistance loads and lower capacitance tubes are used), with intentionally high bandwidth designs going well beyond 1MHz (Tektronix made some excellent amps -- using regular old 12AT7s and 6AU6s -- that did up to 20MHz. Notice they cheat to obtain the last octave and a half by using peaking inductors Now to actually answer your question. Let's take some values on the 300B: Cout: 4.1pF (Cpk) Cgp: 15pF Cin: 8.5pF (Cgk) At a typical gain of 3.0 let's say (a bit less than mu, typical for a loaded stage), Cgp is effectively 60pF, so Cin(tot) = 68.5pF and Cout(tot) = 64.1pF. Let's say you have an even 3kohm load resistor for the plate load, the tube is biased around 300Vp, the supply is 500V and plate current is around 67mA. Assume the resistor has negligible capacitance and your scope probe adds 10pF (reasonable guess for a 10x probe?). The output impedance is thus 740 ohms || 3000 ohms || 74pF, or 593 ohms || 74pF. So, R*C = 44ns. Risetime is often defined as the time taken for voltage to swing from 10% to 90%, but one time constant is only 63%; two time constants is pretty close (85% vs. 80%), so the expected risetime will be around 100ns. The -3dB rolloff is 1/(2*pi*R*C) or 3.6MHz. Not bad, not bad at all. However, this is assuming your grid is driven from a perfect voltage source. It takes a lot of current to make the grid change voltage instantly! You have pretty good theoretical plate bandwidth, but you can't actually get all of it. Let's say your drive comes from something like a 12AU7 cathode follower (12AU7? Sure, why not- in class D, the driver tubes don't matter, they're *supposed* to distort!). Then you'll get ballpark maybe 10mA drive in both directions, which can slew the grid voltage at about 140V/us, enough to turn it fully on or off in about a microsecond (delta V = 140V or so; this would go a lot faster if the output tube had more gain). (A better driver choice might be 6DJ8 or 5687, which have higher gain and current capacity. You still need a fast gain stage to generate the swing, too; a cascoded pentode would be delicious.) As a result, you might only get 500kHz bandwidth, if that. This is pretty close to real observations. If the driver has even less current available (6SN7 plate output is very typical), and your output load has more capacitance (an OPT might cost you a whole nanofarad!), your real bandwidth might drop to a paltry 30kHz, which is, in fact, exactly the observation in many cases. Fortunately, this is still good enough for audio, so we aren't at all worried -- except when discussing the size of one's 'knob'. -=-=- My, this is a reasonably well written, and very detailed, post. This goes in the save bin. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#4 |
Thanks for the thorough explanation!
| Tube rise time and slew rate | gain-wire | Tubes / Valves | 11 | 26th October 2007 02:11 AM |
| Silly question time... | falcott | Everything Else | 4 | 21st November 2006 11:08 PM |
| OpAmp specs: slew rat vs. rise/fall time | rtarbell | Parts | 2 | 6th December 2005 04:38 PM |
| First time builder question | MPM | Multi-Way | 13 | 1st October 2004 10:52 PM |
| Time alignment question | Simon | Multi-Way | 29 | 23rd September 2001 07:46 PM |
| Page generated in 0.12383 seconds (61.70% PHP - 38.30% MySQL) with 10 queries |
