| diyAudio Sponsor | ||
I built the octal Aikido setup from TubeCad.com. I am using the included Tung-Sol 6SN7 tubes and a very simple solid state power supply designed by Sy.
When the preamp is working everything sounds great. After about 30 minutes or so the left channel will about 98% shut off. If I turn off power to the amp output of the left channel will immediately return. I will flip the switch back on and listen for about another 20 minutes. At this point flipping the power switch may or may not make the output return. Everything looks good on the equipment, all the the connections seem solid. The only thing is the tubes dont fit too firmly in the sockets. Any ideas? |
#3 | |
Yup, The problem always stays in the one channel. |
#4 |
First thing I'd do is resolder every joint in that channel.
Do you have an oscilloscope? If so, you can isolate whether the problem is from the voltage amplifier or the cathode follower. See if you can induce the fault by turning a heat gun on the cathode resistors in the "difficult" channel right after the first turn-on and initial warm up. If that doesn't cause the problem, carefully use some freeze spray on the passive parts of that channel- don't get that on or near the tubes or you'll let in the air and let out the smoke.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 | |
#6 | |
Ill try these things this weekend. Unfortunately I dont have an o-scope. I was thinking about getting one of the USB scopes. Do you have any experience with how well they function compared to a convential one? I havent heard of freeze spray, but could I get the same effect from holding canned air upside down? |
#7 | |
Thats not going to happen. The pins on these tung sols seem thicker than most octals. I just tried seating one in my st70 which I have a different kind of socket in and they wont seat all the way in those sockets either. |
#8 |
Any electronics shop or mail order will have freeze spray. You want to really thermally shock the components to see which one is the culprit.
#9 |
I think 99.9% it is a bad solder joint according to your symptoms.I had a similar problem with mine when it warmed up i would get intermittent crackling otherwise sounded great.The solder joints looked good but it turned out one cathode resistor wire was a little short and was not soldered solidly on the pad but was "floating" inside the solder joint.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´ Morgan Jones, Building Valve Amplifiers. |
#10 | ||
Resolder all connections and look at anything with a frosty appearance as being no good too cold a joint and re-do. |
| My Aikido!! | piero7 | Tubes / Valves | 9 | 31st August 2009 10:56 AM |
| Aikido hum | kacernator | Tubes / Valves | 29 | 29th December 2008 12:45 AM |
| aikido problem | jayme | Tubes / Valves | 13 | 20th October 2006 09:59 AM |
| Aikido PSU help | cbutterworth | Tubes / Valves | 48 | 13th October 2006 07:54 PM |
| 3rd Aikido? | philipbarrett | Tubes / Valves | 6 | 11th October 2005 06:35 PM |
| Page generated in 0.12787 seconds (73.96% PHP - 26.04% MySQL) with 10 queries |
