| diyAudio Sponsor | ||
I'm wondering, when one connects the 3rd wire ground to the chassis of an amplifier to prevent the chassis going hot in case of a fault, doesn't this negate the safety benefit of floating the secondary of the primary transformer from the line side? Since the chassis is grounded at the IEC connector on the primary side, and probably through the input/output jacks on the secondary side, I would assume that it is now possible to be shocked just by touching the amplifier B+ or B- supplies and some grounded object, instead of having to touch both sides of the secondary transformer that's completely floating. Is this correct?
#2 |
If I understand the question, yes. Although the HV secondary in the power transformer is center tapped or bridged from ground anyway. So the safety ground is not needed to get shocked while touching the B+ and the chassis.
| May I have some help regarding..Electrical safety,Star Grounding and Suggested Layout | Tripmaster | Chip Amps | 69 | 10th April 2009 08:07 AM |
| Safety ground question | koolatron | Tubes / Valves | 13 | 11th March 2008 05:35 AM |
| one safety question | audio_moksha | Tubes / Valves | 3 | 6th February 2008 06:31 PM |
| Page generated in 0.06785 seconds (68.61% PHP - 31.39% MySQL) with 10 queries |
