diyAudio Sponsor
Old 12th February 2009, 05:32 AM   #1
Bitrex is offline Bitrex  United States
Default Using genetic algorithms to optimize pentode parameters
I've been trying to get back into doing some computer programming after not doing much for many years. Back in college I took a course in "AI" programming techniques, and was introduced to the concept of "genetic programming" to solve optimization problems; i.e. you start with some random possible solutions to the problem, evaluate their "fitness", and then keep crossbreeding/mutating the possible solutions until one that fits your criteria is found. I was thinking the other day that this might be a way to find the optimal component values for a pentode amplification stage at a given supply voltage and desired operating current from the SPICE model instead of resorting to empirical methods since all the parameters interact with each other in a complex way that's a nightmare to find an exact closed form solution from the equations. You could say you had a supply of X volts and wanted to run the tube at a certain quiescent current and optimize it for lowest distortion or highest gain. Or maybe find the "best" operating point for a given tube for a certain purpose. There's no question in this post, really - just thinking out loud.
Old 14th February 2009, 03:26 PM   #2
What you describe sounds like neural net programming. But in any event, I dont think you need anything that exotic. Just use parameter stepping in SPICE to vary as many components you like, plot results, and pick the best combination. This is standard Spice. Some Spices such as MicroCap, and presumeably many others, also have Monte Carlo simulation which could be used to do what you want.
Robert McLean
Old 14th February 2009, 06:21 PM   #3
For those who are unfamiliar with the concept, here's a link:
http://www.damninteresting.com/?p=870#more-870
Current Source <- how to optimize? EE Solid State 85 2nd May 2010 09:08 PM
how to optimize this pentode PP (PP1 clone with S11E12) Jaap Tubes / Valves 3 13th December 2008 01:12 PM
Please help me, to optimize this driver for TL sub christophorus Subwoofers 3 14th January 2007 11:41 AM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
!!>optimize active xover amplifier choice opp Solid State 11 4th October 2005 04:30 PM
Page generated in 0.06573 seconds (73.58% PHP - 26.42% MySQL) with 10 queries
