| diyAudio Sponsor | ||
What size of wire do you like to use for signal wiring?
Gavin |
#2 |
Personally I like small diameter coax..RG-174 comes to mind.
I've used bits of CAT-5 for prototypes,and random experiments,it seems to work well as long as you don't route it near any big sources of hum/noise. |
#3 |
I use CAT-5 as well AND Alpha 24 AWG solid with Tefzel insulation.
#4 |
I use cat 5 and RG-174 small coax also.
#5 |
And I use this: http://www.wires.co.uk/acatalog/cu_gp.html
0.50MM GOLD PLATED COPPER WIRE SOFT, Ref: GP0500S-500
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#6 | ||
http://www.ecpaudio.com |
#7 |
Apexjr carries solid core silver plated copper teflon insulated wire in #20 and #22.
Be sure your foil hat has a good low impedance ground. |
#8 | |
#9 |
I've been using 22ga teflon wire from Johns Silver wire shop.
| Favorite speaker wire? | G | Full Range | 478 | 27th April 2012 10:39 AM |
| Favorite Speaker Wire -- Part 2: Insulation | Bob Brines | Full Range | 37 | 4th February 2010 05:49 PM |
| Your Favorite Signal, Driver & Power Transistor used in your Amp and Why? | John Biles | Solid State | 7 | 2nd August 2005 03:27 PM |
| Wiring my AV12 - what size of wire to use? | BAM | Multi-Way | 3 | 9th January 2004 05:41 AM |
| Page generated in 0.08828 seconds (78.98% PHP - 21.02% MySQL) with 10 queries |
