| diyAudio Sponsor | ||
I have just finished assembling Poindexter's 6GK5/EL34 design as a breadboard, and I am struggling to get past the white-knuckle, plug it in the wall and fire it up phase.
I'm using the PS design shown in the attachment, and so far, have powered it up through a variac. The basic issue is lots of B+ overshoot on power-up that's not reflected in the PSUD model. Upon power-up, with a mains voltage (set on the variac) of around 80VAC or so, the B+ voltage peaks around 450V or so before settling down to the 380/320 values as expected (I crank up the variac to 120VAC after the B+ has settled). This surge lasts a good 30 seconds or so, and I imagine that if I let the PS power up on 120VAC that the B+ would exceed 500V+ for the 20-30 seconds or so. So I'm concerned that I will pop the TS-HA/HB caps with this overvoltage. Could this be ringing due to the 2 L/C sections? It's not reflected at all in the model. I also modeled a 5AR4 CT PS, but I appear to be on the ragged edge of the forward current rating of the 5AR4, so I started with the the SS design. |
#2 |
The tubes take a while to start conducting. So, rerun the PSUD model with 0 current draw and see what happens to your voltage.
http://www.ecpaudio.com |
#3 |
Thanks dsavitsk! Simple enough, that explains it. Changing both current taps to 1 ma ends up with around 540 volts.
Sounds like heating the tubes before applying B+ will solve my newbie dilemma. So I suppose that I need a separate filament transformer and a 30 second B+ transformer delay, or delay the B+ with something on the B+ CT while still utilizing the filament taps in my primary transformer. If I use a 5AR4 design will I still need to use some type of delay? It seems that I will since it will bring up B+ in about 10 sec or so and I need 30 seconds for warm-up. |
#4 | |||
A 5AR4 will give even more HV delay since it's an indirectly heated type. |
#5 |
Thanks Miles. The two issues that I presently have with the 5AR4 design are:
1 Getting to the target voltages without exceeding the forward current of the 5AR4. I cannot seem to get below .75A on the PSUD sims, and I'm assuming that that's the limit. Dual mono's look do-able, but with double the current draw for stereo I'm struggling. If I am interpreting the PSUD error message correctly, I am on the ragged edge for forward current for the 5AR4. Please enlighten me if this is not the case. 2. As mentioned above, don't I still risk overvolting the caps if the rectifier comes up over 10 seconds or so and the output tube filaments take 30 secs? It seems at 10-15 secs I'll have full B+ on semi-cold output tubes overvolting my PS caps. Attached is the 5AR4 PS. The error message says that the recitfier forward current is .78A |
#6 |
Poindexter uses a human powered B+ delay (I just comleted the 6GK5/6V6 and I used it also). Its all on his website. Try it, works perfectly.
PS Love my/his amp! |
#7 |
Have the heater current for parallel 5AR4?
Be sure your foil hat has a good low impedance ground. |
#8 | |
#9 | |
Same treatment for the negative rail: 47uF / 300Vdc units in series. Electrolytics are cheap in comparison to what they may take out if they fail. When wiring in series for higher voltage, be sure to parallel each capacitor in the series string with 100K resistors to ensure voltage balance. |
#10 |
Are there any downsides to using a pair of 5AR4's each with their own CLC feeding each channel?
I would assume that you would get twice the switching spikes in the transformer. |
| Music angel XD-SE EL34 | Kippy | Tubes / Valves | 18 | 12th January 2011 08:36 PM |
| 6v6 music machine build help! | tubo | Tubes / Valves | 26 | 5th November 2009 04:34 PM |
| Music Angel EL34 XDSE | knagy | Tubes / Valves | 1 | 7th October 2007 11:53 PM |
| help me i need schematic of Music angel PP el34 | lilepa | Tubes / Valves | 1 | 8th May 2007 06:09 PM |
| Music Angel EL34 | SimonPearse | Tubes / Valves | 0 | 27th February 2006 08:27 PM |
| Page generated in 0.12858 seconds (77.68% PHP - 22.32% MySQL) with 11 queries |
