diyAudio Sponsor
Old 11th February 2009, 06:18 PM   #1
jcc147 is offline jcc147  United States
Default 6DJ8 biasing question
I'm new to tube and would like to pick this circuit as my first tube project.
Could some one help to understand the biasing method applied on 6DJ8?
Here is my own interpretation:
1. the 2SK117 (BG103) acts as a CCS and it's for active load purpose.
2. 100ohm(R102) is for 6DJ8 self biasing
My question is what current we can expect ? Is it determined by the trim pot R110? or 100ohm(R102)?
Thanks!
Old 11th February 2009, 06:32 PM   #2
dsavitsk's Avatar
The trimmer sets the current. There is a bit of an explanation on how a plate load CCS works here.
http://www.ecpaudio.com
Old 11th February 2009, 06:43 PM   #3
Default Re: 6DJ8 biasing question
Whichever bias resistor achieves equilibrium
at the lower current. Sets limit for the totem.
If roughly the same, whichever device has the
higher transconductance. In this case, the 2SK.
Old 11th February 2009, 08:02 PM   #4
The
I breadboard this circuit and set the pot to get 1mA.
After hooking CCS to the plate with the same pot value, the current has only ~0.15mA measured at the point where current going into 2SK117(S pin). Why is it not 1mA as I expect? And the current makes very less change when adjusting trim pot.
Is the 100ohm too small?
Old 11th February 2009, 08:10 PM   #5
jerluwoo's Avatar
The load on the ccs will also need to draw 1ma. The 6DJ8 is probably only drawing the .15ma you stated. Use a pot for the self bias and then adjust it to get 1/2 b+ at the plate, then measure the pot and use that value for the self bias resistor.
Old 11th February 2009, 10:02 PM   #6
Michael Koster's Avatar
The
100R is an OK value for this low voltage op point.
At 1mA there should be 100mV across the 100R in the cathode and 8-10V
or so from cathode to anode.
How are you measuring the CCS current when you set the pot and then in-circuit with the 6dj8?
Michael
Old 12th February 2009, 03:15 AM   #7
Michael
I set up a simple CCS circuit at the breadboard corner, then move the pot into the main circuit.
Is 100ohm not too small? got ~0.1-0.15mA on 6DJ8, and ~0.25mA on ECC86.
If 100ohm is ok, does that mean I should trim the pot to have ~0.1-0.15mA on CCS?
Old 12th February 2009, 03:26 AM   #8
SY's Avatar
Understand that this circuit will have rather high distortion and very poor overload. Low plate voltage, low bias, grid current...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 12th February 2009, 04:26 AM   #9
I was wondering how you are making the current measurement;
are you measuring the voltage across R102 and inferring the current,
or are you using an ammeter. Where are you connecting the probes
to measure the current?
From the 15V expected at the source of K310, I'd say it was
intended to operate the 6dj8 at a little over 2mA. this would give
a little over 200 mV across R102 and about 18V at the 6dj8 anode.
Michael
Old 12th February 2009, 04:43 PM   #10
Michael
I used a ammeter and connect it between V+ and source of sk117.
I tried a BJT based CCS instead of 2SK117. Here is the circuit I referred:
For some reason, I could get 1mA plate current after switching to BJT CCS method. But next issue comes up about the V plate.
V plate didn't change at all ( or very small) when adjust pot at cathode.
cathode biasing question puginfo Tubes / Valves 7 3rd June 2009 03:24 PM
Hi PPL, I have a question about op amp biasing for you KP11520 Solid State 3 4th March 2008 08:23 PM
question about biasing jsteigs Solid State 2 21st February 2005 12:10 PM
help battery biasing 6dj8's JoeBob Tubes / Valves 14 4th June 2003 01:54 PM
6DJ8 cathode heater voltage question. Morse Tubes / Valves 13 30th January 2003 07:59 PM
Page generated in 0.11365 seconds (86.43% PHP - 13.57% MySQL) with 10 queries
