Is it worth using anything other than DHTs for preamps? - Page 20 - diyAudio
Old 3rd December 2010, 06:03 PM   #191
Is this thread dead ?
I was wondering if anyone considered the european KDD1 double triodes ?
Cheers
Old 5th December 2010, 08:04 PM   #192
I've not seen this tube. There are a few double triodes out there like 3a5, 1J6 and 3B7. The first two sound good - may be a nice sound? Seems to be configured for zero bias, though looks as if it's usable at a bias of 5 to 10v.
andy
Old 5th December 2010, 09:43 PM   #193
dsavitsk's Avatar
Originally Posted by andyjevans View Post
Though it is a LOT like using Kodachrome 25 with Leica glass. It's exactly that crystalline fresh reproduction.
Originally Posted by tubelab.com View Post
Remember the original Kodachrome advertising stated that Kodachrome delivers pleasing color rendition, not accurate color rendition. Worked well for Kodak.
If we are reviving a dead thread, DHTs have outlived Kodachrome -- Dec 30th 2010 is the last day for processing if you have any laying around.
Old 5th December 2010, 10:19 PM   #194
Good call!! I still have my Leica lenses, though I use them on my Canon digital body with an adaptor.
Must be two years since I used film. I'd sell all my camera bodies except they still have bits of film in them and I can't be bothered to finish the films off and process them!!
Anyone want a load of camera bodies - Leica R, Contax etc?
Andy
Old 5th December 2010, 10:51 PM   #195
sad
look like dht TuttoRolleiForum - 60 anni fa: Kodachrome 4x5
Old 6th December 2010, 01:00 AM   #196
dsavitsk's Avatar
It's sad that they never came out with digital backs for some of these. I thought that was going to happen with the Contax G at least.
At any rate, my DHT's have been replaced by transformer coupled differential MOSFET followers, which I must say sound (and measure) better
Old 6th December 2010, 06:16 AM   #197
Too bad about Kodachrome. Best color film I ever used.
Generic Signature
Old 6th December 2010, 10:48 AM   #198
Dsavitsk dht > pentodo and now mosfer ?
http://www.shorpy.com old photo
Old 5th May 2011, 08:37 AM   #199
triode_al's Avatar
Originally Posted by smoking-amp View Post
post 128
Seeing as the DHTs are 100s of times more sensitive to microphonics than indirectly heated tubes (40+ dB), it will be interesting to see if the more microphonic tubes have better DHT sound or not.
The strong 588 Hz resonance on the 1J6G tube I initially measured had a very narrow resonance frequency (only about 10 Hz wide for exiting it from the computer sound card generator) and a very high Q. It would ring for several seconds after I removed the stimulus.
Don
Jumping back in the discussion, and I am just at post 128, I like to note I had a 6J6 for an input in a differential preamp and used that for about ten years, excellent sounding, but also microphonic and it could enter in strange oscillations, induced from strong jumps in passages, giving a metallic ringing of several seconds.
Note the 6J6 is a IHT, with just one central heater.
So I guess it is the mesh wires of the grid that do give this effect.
I gave up on this pre-amp because of the microphonics (with a stepped att this is not practical). For the record.
I built a 3A5 linestage, but never took it in production either. [I am now with Aikido for how long that lasts]
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Cathode feedback and DHTs jane Tubes / Valves 13 1st July 2009 10:54 PM
Anybody try Euro DHTs like RE134, RE304 etc?? andyjevans Tubes / Valves 3 17th October 2008 05:33 PM
DHTs and Cathode Bias 6f6 Tubes / Valves 4 29th March 2007 12:40 AM
How do you put a CCS under a diff. pair of DHTs??? andyjevans Tubes / Valves 5 24th December 2005 03:21 AM
mic preamps travis Solid State 7 20th May 2002 06:59 PM
Copyright 1999-2017 diyAudio
