diyAudio Sponsor
Old 11th February 2009, 05:16 AM   #1
Ziggy is offline Ziggy  Australia
Account Disabled
Default 845SE : comments on this circuit?
Looking for comments or opinions on the attached schematic :
Old 11th February 2009, 05:38 AM   #2
Account Disabled
Of particular interest is the capacitor coupling to the output transformer, bypassing the H.T.?
Is this of any advantage?
Old 11th February 2009, 06:23 AM   #3
Tweeker is offline Tweeker  United States
No DC in the output transformer.
Be sure your foil hat has a good low impedance ground.
Old 11th February 2009, 07:49 AM   #4
dsavitsk's Avatar
Search for "Parafeed" or "Parallel Feed"
http://www.ecpaudio.com
Old 11th February 2009, 09:38 AM   #5
Account Disabled
Aha......so there is little chance of core saturation and almost any suitable impedance single ended output trannie can be used?
In other words, you don't need a high voltage capacity transformer?
I'll do a search as recommended.
Any other comments?
Old 11th February 2009, 10:01 AM   #6
rcavictim's Avatar
Any other comments?
This technique allows one to use any push-pull xfmer as well! That REALLY opens up what kind of iron you can use. With a low enough plate resistance output tube (think a bunch of 6080/6AS7's in parallel), you can even use a toroidal power supply xfmer as the output transformer.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 12th February 2009, 01:03 AM   #7
Account Disabled
Thanks Guys.
Old 12th February 2009, 01:05 AM   #8
Account Disabled
Oh, one last question :
can I get away WITHOUT using the 20h choke inline with the 820v B+ or is this mandatory?
Old 12th February 2009, 01:27 AM   #9
rcavictim's Avatar
That is mandatory. A high wattage resistor can be substituted but circuit efficiency will plunge as will available ouput power. The choke will create higher than the B+ voltage available in output swing. A resistor cannot. The choke has to have enough inductance so as to not saturate at the lowest audio frequencies expected and at the output tube plate current.
Old 12th February 2009, 01:39 AM   #10
It cant be replaced while keeping 820V B+.
It can be replaced with a constant current source (or lower performing resistor) running from over 1600V... You have doubled dissipation in order to have the same output (a sufficiently inductive choke can swing to twice B+).
You cant ignore OPT insulation requirements with parafeed. They are less as you dont have superimposed DC, but that amp will swing well more than 1,000V P-P (note the 3,000V feed capacitor) just in normal operation.
B+ time delay circuit - your comments zigzagflux Tubes / Valves 33 7th November 2011 01:51 PM
Comments on this circuit georgehifi Tubes / Valves 10 10th November 2006 04:46 AM
Comments on Fostex Lab 600 Amp circuit? thejohn Solid State 0 8th May 2006 07:27 PM
Circuit and PCB Layout comments dsavitsk Tubes / Valves 18 4th May 2006 11:56 PM
6C45 PP IT 845SE amp. James D. Tubes / Valves 20 21st June 2003 09:57 AM
Page generated in 0.10251 seconds (81.34% PHP - 18.66% MySQL) with 11 queries
