diyAudio Sponsor
Old 10th February 2009, 07:27 AM   #1
jane is offline jane  Norway
jane's Avatar
Default CF PP design
This is a PPCF design or more precisely a 50% cathode follower push-pull design.
The "50%" refers to the way the driver signal is connected to the cathode followers, between the grids and a 50% tapping at the primary side of the OPT. It is actually a variation over a unity couplet output stage.
Gain in the "50%CF" is ~2 and output resistance from this cathode follower is about 2/gm. A gain of 2 reduces the demand of voltage swing from the driver circuit to the half compared to a plain cathode follower.
There are used pentodes as output tubes and instead of using separate chokes and a capacitor connected to the cathode to make the screen grids track the cathodes there are an extra winding in the OPT to keep the screens follow the cathodes. The capacitor is still included but now just to help the transformer with the leakage inductance between the primary and screen windings.
If you do read Norwegian the whole circuit design is explained in this thread:
http://www.hifisentralen.no/forum/in...?topic=31206.0
Here is a summary of the performance:
All tests measured with KT88 biased at 65mA, Vak=460B, Vgb=310V:
o Power output 40W at onset of clipping.
o THD measured at 1dB below max power: 2HD: 0.4%, 3HD 0.5%, higher harmonics < 0.1%
o THD at 5Vrms@8R: 2HD: 0.15%, 3HD: 0.05%, higher harmonics: < 0.05%
o Bandwidth: 20Hz - 50kHz +/-1dB
o Output impedance: 0.89 ohm
o No global feedback
One of two mono blocs on the test bench:
Jan E Veiset
Life is hard - Then you die.
Old 10th February 2009, 08:01 AM   #2
Geek's Avatar
Neat little setup.
How does it sound compared to grounded cathode?
Cheers!
Old 10th February 2009, 10:46 AM   #3
jane's Avatar
I haven't had the time for serious listening yet, just listen to some small bookshelf speakers at the test bench. I have to make the other monoblock finished before I can sit back with a cold beer and enjoy the music..
Jan E Veiset
Old 17th April 2009, 08:12 PM   #4
SpreadSpectrum's Avatar
Jan,
Have you had a chance for some serious listening yet?
I'm considering building a zero GNF Unity-Coupled amp and was curious how this amp stacks up against other amps you have built.
Old 17th April 2009, 08:57 PM   #5
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
That's a really cool concept.
I'm curious how it sounds too.
Old 17th April 2009, 10:04 PM   #6
jane's Avatar
I think it’s a good sounding push pull amplifier. The output impedance is low enough to give a tight and defined bass with normal speakers and the mid range and treble are smooth and warm.
The weakest part is probably the driver stage with ~10dB local feedback which may cause the amp to start sounding unnecessary harsh when pushed over the limit (We all do that sometimes?). The class A driver doesn’t really need this feedback and in my opinion the amp sounds better without this local feedback..
Jan E Veiset
Old 17th April 2009, 10:09 PM   #7
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Nice amp, but what about cathodes to filaments? Looks dangerous.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 17th April 2009, 10:30 PM   #8
jane's Avatar
It has separate filament supply at cathode potential for each output tube.
You can see the two double (2x 6.3V+6.3V) filament transformers at the bottom of this photo:
Jan E.
Old 17th April 2009, 11:10 PM   #9
smoking-amp's Avatar
A roughly similar scheme is attached. 40% UL taps on the OT xfmr provide 28.5% CFB. Some advantage here in using more than half the primary by each tube for better coupling in class AB during switchoff. The nominally 2K Ohm P-P Hammond 1650T provides about 4K P-P "equivalent" in this configuration.
Could put caps between the cathode and screen of each tube also, less stress on T2 then.
The cathode windings on both sides of ground are both driven by each tube independently (nothing has to pass thru the xfmr to get both phases), so they can be used for high bandwidth feedback taps for a driver stage if wanted.
Don
Ohms Law V = I R
Old 18th April 2009, 12:45 AM   #10
Jeb-D.'s Avatar
Just think, If you did a CF with %60 g2 feedback, you would have an inverted ultra-linear.
Common cathode w/ %40 NFB ~ Cathode follower w/ %60 PFB
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.10859 seconds (74.20% PHP - 25.80% MySQL) with 11 queries
