| diyAudio Sponsor | ||
Hi all,
Working out a preamp idea, please look over this and comment, suggest, etc etc. |
#2 |
I had a go at the Power Supply
#3 |
Hi coldcathode,
Before examining anything in detail I can see a couple things. You might consider regulating your phono pramp section to prevent signals from the output stage from affecting your high gain stage. "Motorboating" may be an issue with this build otherwise. Your "line in" should be terminated to ground with a resistor. Normally you would want to block any DC from external sources also. The grid of your 6CG7 should be referenced to ground to avoid those big noises when switching sources. Where are you going to put your volume control? Your output impedance should be as low as possible in order to drive the cable and input of the amplifier. Most amplifiers are around 47 K, although we are seeing units as low as 10 K these days. Your power supply. A 5U4 to run three signal tubes?? Excessive I think. Consider something smaller like a 6CA4. This will also reduce the heater current draw. Your 12 V transformer is rated too low on current for one, try 1 ampere. It will run too hot as rated. Also, consider running your heaters AC, but biased up 30 ~ 50 VDC. If you really want to regulate your phono heaters, then you need a transformer rated for about 16 VDC. Your regulator may "drop out" on the lower part of the ripple on the raw DC supply with a 12.6 V transformer. Not what you want to hear! Understand that your regulator will get very warm. Use a heat sink and test run it to make sure you do have enough cooling. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#4 |
If you want to use cathode bypass caps, they need to be MUCH larger in value--at least 100 mfd.
#5 |
To somewhat repeat what the others have said:
A 5U4 is overkill. Better a smaller rectifier tube or perhaps nice quite schottky diodes. Decoupling the B+ between the two tubes with an R/C is necessary. Get a fixed resistor or volume control on the 6CG7 grid and a much larger cathode bypass capacitor if you want one there. I would not use an anode follower for the output either. Without running the numbers my gut says you will suffer high frequency response here. Also: The RIAA feedback as shown can't work because the 10uF cathode bypass capacitor puts it at AC ground shorting out the feedback signal. Is that a 4.7 meg resistor in the network? Seems quite large. And why the 47K between cathodes? I'd loose that as well as the other 10uF capacitor. DC for the filaments is good for low hum but you do need a higher voltage to start with. (Higher current here would help too) You can't rectify and then regulate a 12 volt source and expect to still get 12 volts out under load. The regulator needs at least a few volts differential to function. And you need a much larger capacitor off the filament rectifiers. I like to use several thousand uF.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#6 | ||||
Anatech -
The filament supply for the ax7's- I will change to a 30V tranny I have laying around. Rectify that and drop it to about 17V, then use 1 LM7812 per tube and heat sink those, placing them outside the chassis on top in open air. |
#7 | |
Hollowstate: As posted before I agree 5U4GB was overkill, I am revisiting the B+ source as I write this. 470K Grid to Ground added Bypass Caps removed from Phono Section (were not in the circuit that I adapted from Dynaco PAS-2 not really sure what I was thinking) As far as anode follower suffering high frequency loss I do not follow? The circuit info I got from RC-30 indicates that the loss would be well above typical audio frequencies. ie: > 25Khz The 4.7M and the 47K between the Cathodes are in the Dynaco Circuit. I am assuming for a good reason (One that I certainly cannot figure out, LOL but the PAS2 was a pretty well respected circuit correct?) Also as mentioned above the Filament supply will be revised. I am also considering using the 30V tranny and going all DC filaments, using a LM7805 with a 1V diode drop on the ground. Any comments on ALL DC filaments. BTW, will go with 10,000uF Caps after the regulator. |
#8 |
Cathode #3 impedance is so low, the "feedback" from plate #6
through the RC network is completely swamped out. Except at the highest frequencys, where the caps quite simply ground out plate #6. Rather than act as-if a legitimate negative feedback... I'm also unsure what 47K does between two cathodes of low impedance. Probably nothing. -------------------------------------------------- I had a similar idea the other day in regard to a directly coupled cathodyne. What if I fed back the plate to the preceeding stage cathode? Could I lower the impedance at the plate (of the cathodyne) to match the Cathode (of the cathodyne)??? In a word, No. Tried in LTSpice for hours in vain, the impedances of plate V2 and Cathode V1 are just plain incompatible for such feedback without additional buffering in between. All that happens is Plate V2 grounds out though the feedback resisior to no good effect. I even tried CCSink with the "feedback" resistor doubling as the effective "plate" resistor in the cathodyne totem, turned back toward virtual ground as it were... That one didn't work either. I'm not yet sure why. |
#9 | |
Even so, I do own several pieces of Dynaco like the MK-III's, ST-70 & DH-200) but mostly for collector reasons. I also have some of fheir larger output transformers (440's & 451's) that I will build something with when I get the time and physic gasoline.
#10 | |||
Hi coldcathode,
Your main storage goes before the regulator. Small decoupling capacitors go directly before and after the regulator. That's it. You can add RF bypass caps at each heater if you wish. Quote:
Hi HollowState, Quote:
-Chris
| Tube Preamp Idea | mattthegamer463 | Tubes / Valves | 14 | 8th February 2009 12:56 AM |
| An UL preamp idea. | Shoog | Tubes / Valves | 15 | 13th October 2007 06:26 PM |
| Any idea about this mic preamp | zobsky | Parts | 3 | 17th May 2007 01:51 AM |
| Preamp: General Idea | Devil_H@ck | Solid State | 13 | 15th January 2004 03:48 PM |
| Page generated in 0.15201 seconds (79.23% PHP - 20.77% MySQL) with 11 queries |
