#21 | |
Hi tubelab,
My only comment was that the failure mode is normally flashing over between spirals if your applied voltage does not create excessive dissipation right away. I wouldn't be surprised if a normal overheat also causes flash over as the element goes open. As you've discovered, lot's of fun! In short, in most sane applications I find that metal oxide resistors are more than satisfactory. They are not as quiet as metal film types, but they are much less noisy than carbon composition types are. Those ceramic compositions look interesting too. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#22 | |
#23 |
Hi Ty,
Yes, that was what I was thinking when George pretty much proved this as fact. It wouldn't surprise me to see even more of a difference in current draw between pentode and beam tube screen currents. -Chris
#24 |
I think the GU50 has aligned screens.
Be sure your foil hat has a good low impedance ground. |
#25 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#26 |
There is also a larger variation in G2 current with beam tubes, again because of the grid alignment. Looking up roughly similar operation between pp EL34 and 6L6GC (output about 50W), the EL34 variation (0 output - full output) in Ig2 is 20 - 40mA, and that for 6L6GC: 5.6 - 25mA.
#27 | |
According to my musical tastes slight compression is the lesser evil than clipping, even though tube clipping sounds less harsh than SS clipping.
#28 | ||
Hi Anatoliy,
Hi Johan, I think that's one reason I prefer the 6CA7 to an EL34. -Chris
#29 |
I don't know whether I'm qualified to have an opinion on this, but would it be reasonable to use zener diodes instead of screen stopper resistors? The typical applications in some tube manuals specify a specific screen voltage, and it seems to be that that could be conveniently obtained by using zener diodes of appropriate rating. That should also work well with an output transformer having screen taps.
#30 | ||
Zener from B+ source to screen grid reduces constant part of B+ voltage on a screen grid, while almost all variations of B+ voltage will be applied to it. Is it what do you need, or not?
| Metal Oxide resistors in Oz | GK | Solid State | 8 | 18th June 2009 10:10 PM |
| Metal oxide non inductive as emitter resistors in amp | ostie01 | Solid State | 0 | 12th August 2006 08:10 PM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| Ohmite Little Demon and/or Xicon Metal Oxide? | DragonMaster | Parts | 0 | 19th February 2006 08:34 PM |
