#11 | |
I fully agree that metal oxides are good enough for screen stopper duty in an AF amp, but what about a replacement for higher power carbon comps in RF circuits? Would inductance in ceramic composition resistors be as low as carbon comps? The Ohmite data sheet indicates that they are carbon composition replacements. I don't know if that means in every sense. http://www.ohmite.com/catalog/pdf/ox_oy_series.pdf |
#12 | |
The EL34 draws a lot more instantaneous screen current at the moment of "this one goes to eleven" style overload than we think. Under extreme conditions the plate voltage can be less than the screen voltage for a brief instant. The screen can draw considerable current for this time. The average current drawn by the screen grid may be 10 mA leading to a 100 milliwatts of dissipation in a 1K screen resistor. The peak current can hit 100 mA which will burn 1 watt in that resistor for a few milliseconds. I think that the "massive lump of coal" construction that is typical of a carbon comp resistor is far more tolerant of this intaneous overload. The average power dissipated barely warms the resistor. The Metal oxide resistor doesn't seem to tolerant of this brief overload, neither does a metal film resistor. One started sparking around its surface and died in a few seconds. The amp exhibited a rather cool distortion (guitar amp) sound as the resistor was dying. This sound might be marketable to the right metal band! The second resistor just went poof with a small flash, a puff of smoke and a black stain on the PC board.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#13 |
How many turns are we talking? If its ten turns or less...
Some deliberately wrap that many turns on a stopper. Whats the big diff? |
#14 | ||
#15 |
Has anyone tried the ceramic composition types like the OY series from Ohmite or the HPC series from KOA as an alternative to the 2W Carbon Comps for screen stopper applications?
Ohmite OX OY KOA HPC Construction appears to be carbon in a ceramic binder. No spiral cuts. They're about a $1 USD a piece for the 2W size at Mouser. I plan to pick up a few to give them a try on my next Mouser order (which probably won't be for awhile). |
#16 |
Folks,
Let us just examine a few values here. I would respect Tubelab's guess of 50nH - he is seldom wrong. This would equal 100 ohms at .... 1 GHz. The inductance of several leads inside the amp might be far higher than of metal film resistors. I have even used wire-wounds as screen stoppers - Q of about 1.1 - and never had any trouble with this. I did not measure inductance on metal oxide and the like; do not have the equipment. But I did exchange carbon with w.w. and had the merest twich of a peak on a square wave. This particular amplifier had a slight peak at 90 kHz before rolling off moderately fast. In the region 90 - 150kHz where the phase angle becomes large I had no visible difference between carbon and any metal type on the scope display. (This not only for screen resistors but also anode loads for pre-stages.) |
#17 | |
Hi tubelab,
The voltage rating applies to total voltage across the resistor and assumes no other leakage path (imagine a double sided PCB with ground plain on top!). The failure mode is probably arcing between spirals. Your observations would seem to support that. Once the part tracks, it's done. The resistance would drop during an arc over and any tracking would permanently lower the value. So now you have a fraction of a resistor in circuit trying to support a higher current. This part now also has a much lower wattage rating. Complete failure is not a surprise. Your other hypothesis seems likely. A solid composition type resistor would definitely handle surge currents better than any film I can think of. The current density would be far lower in the composition part. I've even seen very large flat wire wound 10 K resistors open up quickly when you have voltages above 550 VDC or so. Very impressive to witness. Try that in the dark! Hi kenpeter, Any inductance from higher value resistors that are wire wound, or helical cut, is not significant at all. I do measure the inductance of metal film resistors before using any new manufacturer. I did find at least one that had significant inductance. That shocked me, but also showed that you can not take anything for granted. The particular resistor I found had been installed by another technician in a quest to improve an amplifier at great cost to the customer. The original tech could not figure out why the amp broke into oscillation. He knew that metal film resistors were not inductive. Well, that one was. In general, most resistors will have a Q that is far too low to cause any problems unless you are operating far above the audio band. For amplifiers that have gain around 1 MHz or higher, it's probably worth testing the part. Otherwise you are worrying about a very small detail. Hi drj759, They sound promising for certain applications. How noisy are they? Mind you, as screen dropping resistors, that probably matters not. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#18 | |
I'm curious about the noise performance too. I thought that with the solid body construction and absence of spiral cuts that they might have comparable surge performance as the 2W carbon comps. They’re at least half the price of 2W CCs (when you can find them). Hopefully my discretionary budget will recover soon and I’ll be able to get a few to try near term. Edit: Looks like SpreadSpectrum had the same idea on the Ohmites (missed that comment earlier): Post #11 |
#19 | |
The failures that I witnessed were in a Simple SE PC board. I usually mount resistors 1/8 to 1/4 inch above the surface of the board, and there are no traces or ground plane under the resistors. I was using 150 ohm 1/2 watt resistor that was rated for 200 volts in series with the screen grid. There is no way I could get 200 volts across a 150 ohm resistor without some real fireworks! 1/2 watt is often called for for screen stopper use, and "normal" dissipation is below 1/2 watt. I have run a bunch of different tubes through the Simple SE under many different conditions. The screen resistor, and everything else remained cool until I put in some JJ EL34's, and plugged my guitar preamp into the amp. Things were still OK, until I dialed up my favorite Jimi preset. After about a minute of this the first resistor started sparking out, some cool distortion ensued, and then silence. I repeated the experiment. First, my old blow proof Chinese 6L6GC, no problem, dive bombing feedback, toggling the pickups on and off on a Les Paul, nothing bad happened. Ditto the KT88's. Enter the EL34. As soon as I held the guitar in front of the speaker and yanked on the pickup switch, the screen resistor acted like a micro Chernobyl. The JJ EL34's are not at fault, they are still hapilly alive 2 years later. I put some 2 watt metal oxide resistors in that board, and they are still alive. This is my test board that has been shown on these pages torturing various tubes, including the incandescent 6BQ5's. I have blown the board up a few times, usually because I got carried away with my variable power supply and cranked 550 volts through some poor tube and blew the cathode resistor or bypass cap. The screen resistors have never fried since I put the metal oxide parts in. They are a bit discolored though.
#20 |
Yah.
Dial up Tubelab, the (ex)terminator, for any know-how about what will last and what not!
| Metal Oxide resistors in Oz | GK | Solid State | 8 | 18th June 2009 10:10 PM |
| Metal oxide non inductive as emitter resistors in amp | ostie01 | Solid State | 0 | 12th August 2006 08:10 PM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| Ohmite Little Demon and/or Xicon Metal Oxide? | DragonMaster | Parts | 0 | 19th February 2006 08:34 PM |
